'95 Bronco Electrical Problem MAYDAY!!!!!
Wiring problem in steering column...Associated with Multi function switch.. When using the High-beam flash or when turning head lights on...Fuel pump power is interrupted. Have narrowed problem to this area ...wiring harness appears to be in normal shape otherwise..runs great ..
used the self test features and received codes that did not match up to any in the Haynes manual other than the EEC 111 (ok) code
any assistance or info on similar problems would be appreciated...
Mr.Fish <t><
