Sponsored by: Real Truck
Official! Changes for 2005
Old Apr 27, 2004 | 04:34 PM
02superstroker's Avatar
02superstroker
So doesn't that solve the plow issue?
Old Apr 27, 2004 | 04:45 PM
DJR 17's Avatar
DJR 17
Whats the problem with coil springs? Coils offer a better ride, better handling, and less noise and weight over the leafs.. I don't think .0005% of SD owners plow snow so if thats all you loose whats the big deal?
Old Apr 27, 2004 | 04:48 PM
02superstroker
Amen! But seriously.. I think this package wil solve even the plow issue.
Yeti.. will it work?
Old Apr 27, 2004 | 04:53 PM
Donahoe's Avatar
Donahoe
What is wrong with Coils and Plows? A Spring is a Spring is a Spring.. If the rate is high enough who cares if its coils or leafs? I'm not a Big plow guy being from Southern California but I do know that spring rate is spring rate. It dosnt matter if its Leaf, Coil or Torsion bar. Is there something on a snow plow system that dosnt like coils?
Old Apr 27, 2004 | 06:08 PM
6.0Diesel's Avatar
6.0Diesel
Yes, this does solve the plow issue. This package makes the spring rate very stiff. Sure your ride will be stiffer, frankly I want my ride to be stiff.
Also, there is a seperate "Plow Package" available.
So basically, I dont see any ill effects of what ford did to the 2005 superduty. Hopefully the exterior changes are good looking.
Old Apr 27, 2004 | 08:34 PM
someday's Avatar
someday
6.0Diesel, from my understanding the strongest front end to get in 04 was the snow plow package (6000 lbs rating) and that was not available for some or all diesels. the heavy service suspension (5200 lbs or 5600 lbs)is nothing new and the rating was less than the snow plow package.
Old Apr 28, 2004 | 05:14 AM
V10man's Avatar
V10man
Other interesting tid bits:
on page 5 it shows 3.73, 4.10 and 4.30 gears available for the V10. That's a first. Could be a typeO. The 275/70Rx18 tires are 33 +" in diameter. (I imagine replacement costs are now double of what 16" tires costs ) There is now a "premium bodyside and lower accent" two tone option. Secondary glove box with autotransmissions. 4 ton hydraulic jack instead of the 2 ton screw jack.
Jeff, if you had to guess, what color is "Dark Stone"? I'm hoping it's a metalic brown of some sort.
Old Apr 28, 2004 | 06:10 AM
jschira's Avatar
jschira
Yep. That would be my guess. Only available with the tan interior, so it must be a brown color, not a grey color.
Old Apr 28, 2004 | 10:25 AM
Ford1TonsRock's Avatar
Ford1TonsRock
Thumbs up F350 2005 and tonka concept
super duty spy pics
http://www.pickuptruck.com/html/2005...ty/caught.html
super duty tonka concept
http://www.pickuptruck.com/html/auto...ord/tonka.html
Ford Mighty F-350 Tonka Concept Technical Specifications
Dimensions
Length: 242 inches
Width: 93 inches
Height: 84 inches
Wheelbase: 165 inches
Track width, front: 74 inches
Track width, rear: 80 inches
Engine
- Power Stroke® Super-600 concept: 32-valve, turbocharged, 6.0-liter V-8 diesel with cast iron block and heads and forged steel crankshaft
- Displacement: 363 cubic inches / 5,954 cc
- Bore: 3.74 inches / 95.0 mm
- Stroke: 4.13 inches /105.0 mm
- Compression Ratio: 18.0:1
- Injection: Electro-hydraulic w/Generation 2 fuel injection
- Turbo: Electronic Variable Response Turbocharger (EVRTTM)
- Emission Controls: Diesel oxidation catalyst, electronically controlled exhaust-gas recirculation
- Horsepower: 350 @ 3,300 rpm (estimate)
- Torque: 600 lb-ft @ 2,000 rpm (estimate)
Transmission
- PowerTorq™ five-speed automatic concept
- Gear Ratios:
1st 3.09
2nd 2.20
3rd 1.54
4th 1.00
5th 0.71
Reverse: 2.88
- Shift control: Fully electronic solenoid control of clutches with adaptive learning capability
Four Wheel Drive System
- Rear- or four-wheel drive with low-range transfer case and limited-slip rear differential.
- Manual Torquemaster override
Suspension
- Front: Live axle with air springs, stabilizer bar
- Rear: Live axle with air springs
Brakes
- Four-wheel disc brakes
- Four-wheel anti-lock brake system
Wheels and Tires
- 22 x 11-inch chrome wheels
- 315/60R-22 Goodyear tires
- Dual rear wheels
Going over the order guides for 2005 Super Duties and Excursions, here's the changes I can see:
Increased Torque for the 6.0L
New mono-beam front axle w/ coil spring suspension on 4x4
New 3 valve 5.4L and 6.8L gas engines
TorqShift trans avail w/ gas engines
Larger Rotors and new Master cylinders on brakes
Engine Idle Control included w/ the 6.0L and 6.8L engines
Upgraded frame for greater Load capacity
Increased rear GAWRs, GVWRs, Payloads and GCWR
Engine Block Heater is optional on 6.0L except for AK, CO, IA, ME, MN, MT, ND, SD, WI, WY.
Trailer Brake Controller - optional
Upfitter switches(4) Located on IP
All new 18" wheels on SRW
All new 17" wheels on DRW
New Grille
New Dual Beam Headlamps
New Front Bumper
New Exterior Badging
New Lower Accent Two-tone Paint Option on XLT and Lariat
New Premium Bodyside & Lower Accent Two-tone Paint option on XLT
Arizona Beige Accent color now available with the XLT Two-tone Paint options
New Secondary glove box on auto trans.
New dash with New gauge cluster
TurboBoost gauge on 6.0L
New Radios
Colors Added:
Dark Stone Clearcoat Metallic (XL, XLT and Lariat)
Dark Copper Clearcoat Metallic (King Ranch Only)
Dark Green Satin Clearcoat Metallic (King Ranch Only)
Colors Deleted:
Estate Green
Chestnut Brown
Deletions:
Max Front GAWR Package
Lariat LE Package
Options Revised:
Power Moonroof now requires Advanced Security Group
Lariat Luxury Package
-Electronic Auto Temperature Control
-Electrochromic rearview mirror
-Bronze-faced instrumentation cluster w/unique gauge color
-Enhanced message centerw/ Trip computer
-redundant Steering wheel controls
-Woodgrain instrument panel insert
-Center console w/ Woodgrain applique
Excursion stays pretty much the same with the exception of 18" wheels now optional on Eddie Bauer and Limited.
Egg crate style grille changes to nostril style
Jeweled Headlights replace crystalline
Old Apr 28, 2004 | 02:18 PM
OverHeight's Avatar
OverHeight
When will the pricing be available?
Old Apr 28, 2004 | 02:40 PM
jschira's Avatar
jschira
Probably a couple/few weeks before Job1 in mid-July. So mid-late June.
Old Apr 28, 2004 | 03:17 PM
Ford1TonsRock
you can always 'build your Ford' online at the ford.com site. I found they update the prices/features available fairly often.
For example -- the King Ranch I bought in December isn't available exactly the same as it was in December and it's a 2004.
Old Apr 28, 2004 | 03:53 PM
  #28
JamesF250's Avatar
JamesF250
Do you think that the grill can be bolted onto a 2002? I like the look.
Old Apr 28, 2004 | 04:03 PM
  #29
Ford1TonsRock
the aftermarket grills avail for the current models are pretty sweet too
Old Apr 28, 2004 | 04:13 PM
  #30
lugnut's Avatar
lugnut
I'm surprised that nobody has mentioned them changing to 18 inch wheels; Is BFG or anyone making good mud tires in that size? If not, I bet they will be soon!
mike
