97 Expedition starting trouble
Old Apr 26, 2004 | 06:46 PM
DTS's Avatar
DTS
Over the last couple of days i've been having a little trouble starting my 97 expedition. When I turn the key a groaning/screeching noise(thats the best way I can describe it) is all I get. It doesn't turn over or anything just the noise. It's done this on two occasions and after a couple of tries it starts up fine. Can anyone possibly give me a clue as to what might be wrong before I have to shell out big $$$ to get it diagnosed and fixed. Thanks!
Old Apr 26, 2004 | 07:55 PM
PaulC's Avatar
PaulC
The bendix drive on the starter may be sticking or failing. This drive engages the starter to the engine's flywheel while the ignition key is turned to the "start" position, and retracts when the ignition key is released from the "start" position to the "run" position.
If the bendix drive isn't fully engaging the flywheel when you attempt to start the engine, the spinning gear driven by the starter will lightly contact the stationary teeth on the flywheel with noisy results.
F350fireman
Aug 18, 2011 09:25 PM
BigDude97
20
Sep 15, 2010 06:10 AM
Mav06
Mar 6, 2007 07:05 AM
duece_bigalo01
Dec 30, 2006 09:36 AM
b_massey
Jan 6, 2006 08:01 PM
