Signal lights
Old Apr 26, 2004 | 05:58 PM
mild 02's Avatar
mild 02
Signal lights
Well when I first got my truck the dash lights didn't work and the blinkers worked but really slow. This weekend I was going down the road and the dash lights started working and the blinkers stoped. Looking under the dash it seems to be in pretty good shape (no birdsnest) but what are some thing I could look for, I need to get it inspected.
Old Apr 26, 2004 | 11:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Look for bad grounds, corroded connections, bad crimp joints, corroded bulb sockets.
Old Apr 27, 2004 | 12:34 PM
Freightrain's Avatar
Freightrain
If the blinkers were sssslllloooowwww, then I would start with a new blinker relay.
Your dash lights work off the headlight switch. If you rotate it, the lights dim and you can turn ON the interior light. My switch is a little rough and the dash lights only work in certain spots. If I turn on the interior lights, the dash goes out....just a bad spot. NO big deal.
Old Apr 28, 2004 | 10:17 PM
mild 02's Avatar
mild 02
Where do I find the blinker relay?
Thanks in advance
drewduncan15
Dec 31, 2012 05:38 PM
bbokainen
Mar 30, 2011 08:56 AM
onlya4.9
Oct 30, 2010 03:41 PM
Fordman_Evs
Sep 13, 2010 09:46 PM
