1978 - 1996 Big Bronco
Please help, engine codes
Old Apr 26, 2004 | 11:23 AM
kameronth's Avatar
kameronth
Maybe every other day or so I will start up my bronco and it will be missing bad. So i did the KOEO test and I got these two codes, A 22 and 32. I think one is for the MAP and the other is EGR. What should I check or replace and could the MAP or the EGR cause my engine to miss? Again it does not always miss, just does it when it wants. Thanks for the help. Seems like everything breaks at once! My rear diff, gas cap, and now this.
Old Apr 26, 2004 | 11:38 AM
Krelek1000's Avatar
Krelek1000
Check vacuum lines and voltage of wire to the sensor. If your Lines are fine and voltage are good, replace sensor. EGR could have a plugged vacuum line. When engine is running pull line and feel for suction.
Old Apr 26, 2004 | 02:09 PM
moritz1024's Avatar
moritz1024
code 22 reads bp sensor out of self test range
code 32 reads evp voltage below closed limit
Old Apr 26, 2004 | 09:48 PM
kameronth's Avatar
kameronth
Sorry but I messed up. When I first started feeling my truck miss I pulled the map sensor and the egr off to look at em and I forgot to reset it. Now I reset it and the continuous memory codes were fine. The KOER test pulled up a code 44. The scanner book says problems in the thermactor air control? What the hell does that mean?
rickdavis81
May 12, 2016 04:34 PM
Gokussj5okazu
20
Oct 13, 2015 04:52 PM
anthonym92
Jul 7, 2015 09:52 PM
ANigrelli132
Dec 5, 2014 10:49 PM
Jrbursee
May 9, 2014 04:24 PM
