rearend gears
Old Apr 26, 2004 | 02:05 AM
frigerator's Avatar
frigerator
rearend gears
I've got a 64 f100 292 w manual 3 speed and I'm running 295/50/15 . What would be a good gear ratio to run so that I've got good take off and not whinding 5000rpms when I'm going down the freeway at 70
Old Apr 27, 2004 | 09:27 AM
Mike G's Avatar
Mike G
What gears do you have currently? I believe the 3:70's are a popular choice with a hot motor in these trucks.
Just MHO, --Mike
Old Apr 27, 2004 | 12:02 PM
MercuryM100's Avatar
MercuryM100
Forgive my lack of knowledge on this issue...but what exactly does gear ratio have to do with power/speed etc...?
My truck is a 240 manual 3 and is running a 3:70. I hear mention of tire size, gear ratio, etc...lost in the newbie world here...
Chad
Old Apr 27, 2004 | 02:41 PM
scamardo's Avatar
scamardo
Hey Chad,
Easy to get lost. Look at it this way. With the right gearing, you can do 8 sec in the 1/8th mile with a Lawn mower engine. (Check out Jr. Dragsters)
Not exactly sure on that tire size, but I bet a 3.25 pumpkin would serve you well. I run a 390 with C6, 3.54 diff and 255/70 15's and hit 3000 at 70.
Old Apr 27, 2004 | 02:47 PM
Mike G's Avatar
Mike G
I'll give this a shot but not being an expert myself, maybe some more "experienced" folks will assist. The gearing has a lot to do with how your truck moves. If you have gears that are 4:11 or what I would consider "deeper" (like the 5:56 range)your truck will leave a start line hard and fast, but will max out more quickly. If you have what I call "taller" gears, like 3:70's, your truck will not launch as hard and will take a little longer to wind up, more for say highway driving (but I need to mention most have a 1:1 final drive). Also, the bigger the tire, the more work to move your truck, causing and affect similar to go with "taller" gears.
Let the beatings begin if necessary
--Mike
Old Apr 27, 2004 | 04:10 PM
MercuryM100
Ok, Ok, so it's making more sense...
I am actually buying new tires either tonight or tomorrow, and was planning on purchasing 235/75/R15...with my truck info as I posted earlier is there a differerent tire suggested?
Scamardo...what are referring to as a 3.25 pumpkin?
Old Apr 27, 2004 | 04:26 PM
Mike G's Avatar
Mike G
The 3:25 refers to the gear set in the "pumpkin" or case on the front of the rear axle.
--Mike
Old Apr 27, 2004 | 04:53 PM
MercuryM100
(All this secret terminology...feel like I just entered a frat!)
Old Apr 27, 2004 | 06:20 PM
scamardo's Avatar
scamardo
Yes, Mike is right.
You can get any pumpkin from any Ford 9 inch and use it in your truck to play with. Only catch is, you gotta make sure the spline count of your rear axles match. In other words, if you have 28 or 31 spline axles, then the pumpkin has to match. If in doubt, pull your rear axle and count them.
You can get a used pumpkin at a junkyard for $50 or less.
Old Apr 27, 2004 | 06:51 PM
44dwarf's Avatar
44dwarf
I'm a member of Tapa-kega-brew my self.....
I've posted this link before you should all book mark it.
http://www.parkercarburetion.com/calculators.html
It will let you play with tire sizes and rear end ratios to see rpms at a given speed or visa versa.
44
PS: check out all the calc's there good reference.
Old Apr 28, 2004 | 02:08 AM
frigerator's Avatar
frigerator
I wished I lived in Charlotte. The pumpkins run from $150.oo -$300.oo in mid to lower Oregon and I can't find a 31 spline 3.25
Old May 11, 2004 | 03:08 PM
nd4spd's Avatar
nd4spd
I was wanting to replace my rear end gears with someting with more bite...mine has 3.08 gears in a 90 F-150 1/2 ton....how does the 3.08 compare to the 3.55's? thats sorta what im looking to put in 'er.....With the 3.08 in it now its great, feels like it wants to lift offa the ground (did some mods to it) but was curious to see how the 3.08's stand up against some other gears...thx
nd4spd
Old May 11, 2004 | 03:31 PM
scamardo's Avatar
scamardo
He-he, with your setup, it would run like a scalded dog! My 65 is probably a little heavier than yours, especially with the 390 FE in mine, but I am running a C6 tranny and a 9 in rear. I am sure you can get that gear set in the 8.8 (that is what you have right?) Really depends on what you want to do. Daily driver, red light racer? Concerned about fuel mileage? If so, keep what ya got.
Old May 12, 2004 | 09:01 AM
nd4spd's Avatar
nd4spd
Red face
Yeah, with gas @ almost $2.00 a gallon! im a lil bit concerned lol....maybe when prices go down, I will swap it out...you know, im not sure if i have an 8.8 or not....im not a real rear axle buff Hell it runs like a scalded dog now...i want it to run like a dog on fire! haha
Old May 14, 2004 | 10:11 AM
oldroady's Avatar
oldroady
my 65 250 has 4.10's in it. even with 235/85 16's it sounds like a nascar race on the freeway. something about 3.70 would be a lot easier on things. on the other hand, i can pull down trees.
