Another 351C question
Old Apr 25, 2004 | 07:09 PM
thunderguns71's Avatar
thunderguns71
Ok I have a 351C that I thought about building awhile back but other things got in my way, but Ill be ready for it soon. The block has been checked and cleaned just needs to be bored. I have a set of 2bbl heads that has been completly redone that is with it. So here goes. How much hp can I make with the 2bbl heads and with 4bbl heads and anythings goes. Anyone want to give me their best shot at this. Would like to do this NA but a superchager isnt out of the question. The end result is sumthing streetable {barely} I know I have about two main options, low compression and a SC or just high compression all motor, and ofcourse since octane sucks now a days high compression may be out of the question. Anyways post away , teach me somethign here,
Thnaks
Old Apr 26, 2004 | 01:49 AM
pcmenten's Avatar
pcmenten
Would you do me a favor? Measure the space between the cylinders in the water jacket? I'd like to compare that to my Oz Clevo to guestimate the cylinder wall thickness.
Old Apr 26, 2004 | 07:49 AM
78ford100's Avatar
78ford100
Check out the Parker funnelweb website, they've got dyno printouts on there.
http://www.madhatterracing.com/funne...nnelweb2Vs.htm
Old Apr 26, 2004 | 08:34 AM
thunderguns71
i measured 7/64"
Old Apr 26, 2004 | 10:33 PM
pcmenten's Avatar
pcmenten
7/64 or .109". My Oz block is about .090" in the widest spot.
The bores are .485" apart.
Your block's walls might be as thick as .188" but probably a bit less. Mine are no more than .197" thick.
I've heard that Cleveland blocks cannot be bored more than .030 but it sounds like that may be an overstatement.
I plan on converting my engine to roller cam and installing a stroker crank. I want a street engine so I'll be making sure that it has quench (Oz heads) and an iron intake.
Rusty_S
Jun 22, 2016 07:52 AM
Rusty_S
Jul 22, 2015 01:40 PM
shiftless
Oct 27, 2006 10:11 PM
stretch351c
May 23, 2005 11:22 AM
danielbridgs
Jan 27, 2004 07:46 PM
