idle air control valve
Old Apr 25, 2004 | 07:04 PM
greenterror's Avatar
greenterror
my truck was idleing up and dowh then would stall,so i cleaned the idle air control valve.a little better then i replaced it well when i started the truck the idle stayed 3000rpm and wouldn't move. what do ya think
Old Apr 25, 2004 | 07:59 PM
jclj2003's Avatar
jclj2003
it sounds like it is stuck open to me i never had this problem but i haave read alot on it just my 2 cents also try a bootle of sea foam it works great
Old Apr 25, 2004 | 10:06 PM
ltfox's Avatar
ltfox
People have mixed results with just cleaning the IAC. Sometimes it works and other times you gotta buy a new one.
Old Apr 25, 2004 | 10:25 PM
Bashman's Avatar
Bashman
It sounds like a vacuum leak. Double check all vacuum hoses and ensure they're connected and all caps are in place. From what I read you have already replaced the IAC so that is ruled out. Biggest cause of all high idle probs is a vacuum line but occasionally a TPS is at fault.
pikiluvi
18
Mar 10, 2026 04:33 PM
ramrodder007
Missouri Chapter
Apr 2, 2013 12:54 AM
kanepjk
Bronco II
Mar 30, 2007 09:28 AM
Uncle Bob
Nov 21, 2003 12:51 PM
jowilker
Nov 17, 2002 07:05 PM
