1978 - 1996 Big Bronco
Balancing large 4x4 tires
Old Apr 25, 2004 | 05:07 PM
Trublufords's Avatar
Trublufords
I have heard about someplace that is bubble-static balancing large 4x4 tires. Time consuming, but with great results!! They first mount tire to wheel , then bubble-static balance. mark area with weight amount. index tire to wheel, then dismount tire and then glue-seal a rubber ball(??) weight bag to inside of tire.Then they mount the tire back on making sure it is indexed with wheel and then dynamic balance the assembly.I was told 1 to two ounces is all that is needed!!! Anybody know more about this(or who)????? I am putting Trxus sts 39.5 on my son's 93 Bronco, also I would like less weights on my 95 Bronco!!
Old Apr 25, 2004 | 05:46 PM
dyarumian's Avatar
dyarumian
is it even worh balancing a 39.5? most people around here dont bother on anything bigger than a 33"
Old Apr 26, 2004 | 10:40 PM
tite4x4's Avatar
tite4x4
Here is another option: there is a product called Equal. It's almost like a powder that goes inside the tire when mounted and by centrefugeal force the Equal is spread thu out the inside of the tire. Here is more info to better explain. http://imiproducts.com/imi_htmlcode/...i_fs_news.html
BTW - When mounted let me know how you like them, Both off and on road. I have been considering getting a set of them when my current tires wear out. Thanks
Old Apr 27, 2004 | 05:33 PM
bossind's Avatar
bossind
Have you tried Equal? Is there any down side to it? It sounds perfect! I'm tired of rebalancing my wheels, but it does sound to good to be true.
Old Apr 27, 2004 | 06:14 PM
ubermich's Avatar
ubermich
some guys on the full size jeep forums use sand and/or golf ***** to do the same thing equal does... Equal just looks to be plastic sand to me actually... If you don't mind the noise, I've met several guys who swear by golf *****. (note that the noise is only while stopping/starting, as they settle into place once you're moving)
Old Apr 27, 2004 | 06:30 PM
Tidybowlman0's Avatar
Tidybowlman0
I would think sand would work.
Old Apr 27, 2004 | 06:48 PM
bossind's Avatar
bossind
It would be hard to get the golf ***** through the valve stem! Hee hee. Sand might be a problem up here in the snow belt.
Old Apr 27, 2004 | 07:11 PM
tite4x4's Avatar
tite4x4
I haven't tried the Equal yet. The golf ***** is a complete nono for me since I hate golf, So maybe using them for pea shooter.
Old Apr 27, 2004 | 10:18 PM
greystreak92's Avatar
greystreak92
39.5's! You shouldn't be going fast enough with that much meat to warrant balancing! Seriously though, I know several people who swear by the Equal stuff.
Old Apr 27, 2004 | 10:25 PM
bossind's Avatar
bossind
So does that equal add noise to the ride? And are the tires out of balance untill the tires get up tp speed? Or does it act like regular wheels that are balanced on a machine?
Old Apr 28, 2004 | 08:15 PM
tite4x4's Avatar
tite4x4
This topic is being talked about in the offroad and 4x4 forum also. https://www.ford-trucks.com/forums/s...1&page=1&pp=25
