question about sensor location.
Old Apr 25, 2004 | 01:52 PM
yup's Avatar
yup
hello
my check engine light was on so i used my code reader and got a code "133" which according to the book said was a "o2 sensor slow to respond" well according to my haynes manual it said that the code was refering to the "air charge temperature sensor in a "stuck open" state. well this would correspond with a broken check valve on my exhaust gas recirculation system. so i went and got a replacement check valve (god bless napa they had only one in WHOLE town) and a new a.c.t sensor. so i replaced the check valve and went to replace the sensor jic and looked in the haynes book at the picture.... well on my truck where the sensor is supposed to be is nothing .. no hole.. nothing capped off... its just not there... does anyone no where this sensor is?? do i really need to replace it?? i figure with the truck getting up on mileage and i had already bought it it would be a good idea to go ahead and replace it since i had already replaced the check valve.. but where is this sensor supposed to be???
Old Apr 25, 2004 | 02:39 PM
acerockola77's Avatar
acerockola77
I just looked up code 133 and I couldn't find anything, is your truck a 96?
Old Apr 25, 2004 | 07:04 PM
yup's Avatar
yup
yup 1996 f150 4x4 5.0 5 speed, now just looking for this "mystery sensor"
Old Apr 25, 2004 | 07:12 PM
yup's Avatar
yup
bump if anyone can tell me where the air charge temperature sensor is located???
Old Apr 26, 2004 | 01:33 PM
Frank Lang's Avatar
Frank Lang
A mechanic once told me it is in the air intake--but I haven't looked to see if that's true. I assumed it was.
Frank.
Old Apr 26, 2004 | 04:21 PM
yup's Avatar
yup
i finally found it, its in/on the air intake airbox, although the haynes manual says its supposed to be in the intake manifold...might be a maf/sd screw-up i guess...
