Fuel Pump Power
Old Apr 25, 2004 | 07:37 AM
black874x4's Avatar
black874x4
Fuel Pump Power
1987’ F150 5.0 w/ dual tanks.
Asume that both low pessure pumps are operable.
Both of the low pressure fuel pumps are not running while the high pressure pump operates normally. Does the inertia switch kill power to the high pressure pump as well ? Does the in-tank pumps rely on a ground through the mounting straps? The truck ran a month ago, but has been sitting most of the time for the past year. Any suggestions? Thanks in advance.
Old Apr 25, 2004 | 01:00 PM
black874x4's Avatar
black874x4
Never mind, I fixed it.
Old Apr 25, 2004 | 05:19 PM
MattA's Avatar
MattA
what was your problem.
I think I may have the same problem with the secondary pumps not getting power.
what did you do to fix it?
Old Apr 25, 2004 | 07:47 PM
black874x4's Avatar
black874x4
I traced good juice to the pump (front tank), in doing so I moved a lot of wires around and must have accidentally gotten a good ground. I believe that the tanks share a common ground wire and I have had the problem of grounding on this old truck before.
oldford65
May 21, 2013 07:42 AM
Jordanz_03
Mar 12, 2012 02:27 PM
88 250
35
Oct 6, 2010 07:53 PM
lopitt85
Sep 1, 2009 08:54 PM
master link
Aug 24, 2006 11:19 AM
