Another engine mount/swap question.
Old Apr 25, 2004 | 07:12 AM
TheMachfather's Avatar
TheMachfather
The 390 is ready to go down in my '77 finally. Is there any way I can use my current 460 frame mounts? If not what all trucks can I get the mounts from? Any pre-73? Does it have to be a 4x4 to work w/ my 4x4 or will a set of mounts from a 2wd work?
Old Apr 25, 2004 | 10:07 AM
oldhalftons's Avatar
oldhalftons
390 uses the same mount towers as a 300 6cyl
460 conversion mounts are different for 2wd and 4wd
Old Apr 25, 2004 | 10:09 AM
TheMachfather
Thats cool then...so I just need a set of 300 I6 frame mounts? will 2wd work or do they need to be 4wd? What all year trucks can I get them from.
Old Apr 25, 2004 | 10:19 AM
oldhalftons
2wd or 4wd, 73-79
the steel mount towers that bolt to the frame are the same for FE big blocks and 300's, there are a couple sets of bolt holes on the frame, 300's bolt to one, FE's bolt to the other.
just use 390 mounts on them.
Old Apr 25, 2004 | 10:20 AM
TheMachfather
Well problem is I dont have frame mounts for the 390. I have the rubber mounts but I need the frame mounts...those are what's keepin me from putting it in right now.
