There's nothing to it--there are two coolant lines running into the throttle body. Remove the two clamps, remove the two hoses, and hook them together with a brass coupler that you can get at any hardware store.
Your TB will actually be cooler if you hook the lines together! Cooler TB equals cooler intake air.......since it is denser there is a little more HP. If you live in EXTREME cold areas, you might want to leave it connected because it helps keep the TB butterfly from freezing up by running the coolant through them....
