Rancho 9000's installed !!!!!!!!
Old Apr 24, 2004 | 05:53 PM
jdadamsjr's Avatar
jdadamsjr
Talking Rancho 9000's installed !!!!!!!!
Got the 9000's installed on the Ex today and on the ride home was SO disappointed - rode like the proverbial brick !
Got home and in the misty rain HAD to lay out a throw rug so I could look at the install...
Everything looked fine... then started checking the settings on the 9 way adjustables...
Left front on 3 --- should have been little less than middle of the range....
right front and rears were all on NINE
So changed them all to one and went for a ride...
Now it seems SOFTER than stock :-)
Guess I'll have to find my happy medium....
what do any of you run the Ranchos on ???
and will definetly look into the dash adjustment kit !!!
Old Apr 24, 2004 | 07:07 PM
jschira's Avatar
jschira
3/5 not towing
5/7 towing.
5/7 is a little stiff.
Hmmmmmm, maybe 7/5??? More weight in the front.
Old Apr 25, 2004 | 10:21 AM
jdadamsjr's Avatar
jdadamsjr
Thanks J...
will try that...
did u get the dash adjusters ?
may opt for that since I'm a lazy boy :-)
Old Apr 25, 2004 | 12:04 PM
jschira's Avatar
jschira
No, still young enough that I can crawl under when I need to.
Old Apr 25, 2004 | 12:43 PM
jdadamsjr's Avatar
jdadamsjr
:-x24 :-x24 :-x24
Old Apr 26, 2004 | 06:41 AM
LabCab's Avatar
LabCab
I have mine set to 5 all the way around. I may try to adjust them down some. Towed with the rig this weekend, a 5000lb trailer and it towed great at 5. I will adjust down to 3 while not towing and see if I like it better.
Pat
Old Apr 26, 2004 | 08:14 AM
jdadamsjr's Avatar
jdadamsjr
Talking
Crawling under is not the problem J...
it's that getting back up
and I've found the fronts can be reached over the tire now that I know where they are...
I LIKE 'EM
but can't understand why you would EVER run them on 9 ---
for SERIOUS TOWING !?!
it was amazing the difference in the "harshness" of the ride...
but neat with all that adjustability !
Old Apr 26, 2004 | 09:04 AM
jschira's Avatar
jschira
Did you mount one of the fronts with the little **** facing forward and one facing backwards? That way, if you turn the wheel, you can reach both ***** without crawing under.
Oops. Probably should have mentioned this little trick a few days ago.
Old Apr 26, 2004 | 11:13 AM
jdadamsjr's Avatar
jdadamsjr
Oops is right :-)
I dind't install them... too lazy for that :-)
had it done @ Mansfield Gas and Exhaust for $40...
i can reach over the front tires and get to either...
just that counter-clockwise versus clockwise thingy is the next hurdle !!!!!!
