gear ratio
Old Apr 24, 2004 | 08:11 AM
Brian77Ford's Avatar
Brian77Ford
gear ratio
I have a 1977 F150 with a 351m in it. I was wondering if some one knew what rearend gears I might have.It has a ton of power and torque but no speed.If you take your foot off the gas it will actually lose speed.It is also an automatic.
Old Apr 24, 2004 | 01:52 PM
FordPickup460's Avatar
FordPickup460
It should have a 9" rear end. Look on top of the rear end and there should be a tag that says what gear ratio it has.
Old Apr 24, 2004 | 02:51 PM
Ecuri's Avatar
Ecuri
If the tag is gone, jack up the back under the diff. Get some one to help you turn both tires one full revolution as simultaneously as possible in the same direction (assuming an open diff). Count turns on the driveshaft. Cheers. I bet $1.00 on 3.25.
Old Apr 24, 2004 | 05:48 PM
77300i6's Avatar
77300i6
I bet $5 on 3.50:1 gearing
Old Apr 24, 2004 | 07:02 PM
supercab4x4dually's Avatar
supercab4x4dually
I will go $10 their 3:54's
Old Apr 24, 2004 | 08:00 PM
cannonfodder's Avatar
cannonfodder
I'm with supercab
Old Apr 24, 2004 | 08:04 PM
cannonfodder
Smile
You can jack up one wheel and turn it twice
Old Apr 24, 2004 | 09:32 PM
LxMan1's Avatar
LxMan1
I'll have to take your $10 Supercab. A F150 would have a 9" and 3.54's weren't available in a 9". You could get 2.75, 3.00,3.25,3.50,3.70,4.10.
I'll take cash please.
On a 2wd, 3.00 is pretty standard from what I have seen. Depending on what size tires that it has on it, it could be 3.25 or 3.50.
My 351M/C6 truck that is now 460 powered had a 2.75 originally. I put a 3.50LS out of a 86 4x4 Bronco in it.
Old Apr 24, 2004 | 10:22 PM
coolmint94's Avatar
coolmint94
My brother has a 79 with a 351m and 2wd that has 2.75 gears. my 4x4 has 3.50
Old Apr 25, 2004 | 09:42 AM
Brian77Ford
The tag is gone.It is a 4x4.All I know is it is geared low for pulling.The original owner told me he specal ordered lower gears but forgot what he orderd.
Old Apr 25, 2004 | 10:13 AM
telesqrt's Avatar
telesqrt
I would guess 4.10's. The higher numerical gear ratio's (3.70, 4.10 etc.) tend to give more decompression related slowing when you let off of accelerator pedal as to the lower numerical gear ratio's (2.70, 3.00, etc.) which tend to let you coast longer. Sorry, no money, cann't afford to lose any. Bank acount like a sieve.
Old Apr 25, 2004 | 10:34 AM
biggieou's Avatar
biggieou
Wouldnt bigger tires effect the gear ratio also?
Old Apr 25, 2004 | 11:41 AM
mikebon08's Avatar
mikebon08
Yes--bigger tires act the same as higher (numerically lower) gears.
Old Apr 25, 2004 | 05:31 PM
Brian77Ford
It has regular tires on it.So I'll go with the4.10.Thanks alot for all the replys.
Old Apr 25, 2004 | 06:08 PM
supercab4x4dually
Both my 78,and 79 1/2 ton's have 9"s with 3:54's.The Tag on the Bronco is still their,and it say's 3:54's LX Man. Are we talking 4x4 0r 2wd?
