keypad code
Old Apr 23, 2004 | 10:00 PM
msu_fan's Avatar
msu_fan
keypad code
My parents just purchased a 2000 expy xlt. The dealer didn't know the code to the keypad, is there any way to find out this code?
Old Apr 23, 2004 | 10:10 PM
horseman1's Avatar
horseman1
Lay on your back in the drivers floor, with a light, look up under the dash and you should see a box on the right hand side with a 5 digit # that is the master code....
Old Apr 23, 2004 | 10:28 PM
PaulC's Avatar
PaulC
That's right. Also, check out the packet that contains the owner's manual for a white plastic card that lists the numbers.
Old Apr 23, 2004 | 10:52 PM
fordborn's Avatar
fordborn
sometimes they will also be put in the engine compartment so look there also. And as for the dealer not knowing it , well was it a used car dealer? Because any Ford dealer can put it on the computer and get the number for you.
Old Apr 23, 2004 | 11:23 PM
xpy99's Avatar
xpy99
Under the dasjh on the right is where I found mine.
Old Apr 24, 2004 | 04:13 AM
ecajberry's Avatar
ecajberry
Talking
Drivers side, left of the break pedel, up under the dash is where mine was.
Old Apr 24, 2004 | 11:23 PM
msu_fan's Avatar
msu_fan
Thanks for the help, I found it under the dash.
Old Apr 25, 2004 | 12:02 PM
HomerWinzlow's Avatar
HomerWinzlow
You can also program it with your own 5 digit code. Just enter the factory code, followed by the 1-2 button once, then a five digit code of your own. The original factory code will always work regardless what personal code you program in. Follow each step within 5 seconds of each other.
