hard shut down
Old Sep 4, 2002 | 07:27 PM
88B_RONC's Avatar
88B_RONC
hard shut down
I have noticed that sometimes when I shut my engine off it rattles/cackles/shakes (whatever) alot with a rough sound. It runs great on the road but I was wondering what this could be or should I even worry about it?
thanks
Old Sep 4, 2002 | 11:27 PM
Jackson's Avatar
Jackson
hard shut down
My truck use to shut down real hard till I changed the clutch. Have you changed out the original dual mass fly wheel?? That seemed to be the problem with mine.
Old Sep 5, 2002 | 08:17 AM
JoeBoost's Avatar
JoeBoost
hard shut down
My truck will do this as well once in a awhile.
When i turn the key off - truck shakes real hard - never thought
it could be an issue...
Old Sep 9, 2002 | 01:32 PM
basstardo's Avatar
basstardo
hard shut down
Would you be able to test this by pushing the clutch in during shutdown maybe?
basstardo
Old Sep 9, 2002 | 07:51 PM
c_nate's Avatar
c_nate
hard shut down
Were the springs loose in the dual mass flywheel. got a 94 IDI turbo that does the exact same thing. not all times just on occasion.
Nate
Old Sep 9, 2002 | 10:41 PM
otto's Avatar
otto
hard shut down
that dual mass was a joke, replace it with a single mass for 1/4 of the price
Old Sep 10, 2002 | 10:10 PM
c_nate's Avatar
c_nate
hard shut down
then whats the reason for having a dual mass flywheel. got to be one. would seem foolish to go replacing it. My guess it helps smooth out the engine pulsations. installing a regular flywheel might put additional stress on the crank also. just some rambling thoughts.
N
Old Sep 11, 2002 | 07:27 AM
fatbob's Avatar
fatbob
hard shut down
my 96 has had hard shutdowns since the day i picked it up from the dealer, no exceptions. It doesn't seem to have hurt anything. My only problem was the first three glow plug relays...they would only last six months.
Old Sep 11, 2002 | 04:03 PM
Jackson's Avatar
Jackson
hard shut down
Yeah the dual mass flywheel seemed pretty worn when I replaced it. Like I said, after that the hard shut downs were not there anymore after I replaced the dual mass. As for the solid luk flywheel putting more stress on the crank, I checked on here with people who had installed the luk solid and also checked with some of the on-line clutch vendors to see if there would be any additional vibration with the luk and if it would create other problems. Some said they noticed a slight bit of vibration others said they noticed no change at all. My experience is that the luk is working very well. The pedal has very little resistance compared to the stock dual mass and everything seems to be working well. Very little if any difference in vibration.
Old Sep 11, 2002 | 09:13 PM
otto's Avatar
otto
hard shut down
>N
ask ford they went back to a single mass when they debuted the super duty line up in 97
Ever bought a dual mass?, when you do go to buy one go into the place and walk with your butt real close to the wall cuz they will bend you over bad to the tune of about $1000
Old Sep 11, 2002 | 11:55 PM
88B_RONC's Avatar
88B_RONC
hard shut down
I tried pushing the clutch in when I shut down a couple times today and it seemed to help keep the shaking to a minimum. So does this mean my clutch is going bad or is my dual mass flywheel the problem?
Old Sep 12, 2002 | 09:20 PM
otto's Avatar
otto
hard shut down
when my dual mass went out it vibrated badly at idle, so bad the chrome front bumper was flexing and shaking at idle, still driveable, i knew this was the problem so i got a clutch and what not, ripped the tranny out dual mass was totaly demolished all the bearings fell out and had flat spots wore on them also rusty, all the springs were broken also, transmission was a 1 piece with built in bell and the bell was cracked 70 percent of the way around welded it put it all back in, it was a bear to get in since its one piece and it is so tight against the passenger side floor with the flatened out exhaust pipe right next to it, got in tho and no problems
Old Sep 13, 2002 | 08:41 AM
Jackson's Avatar
Jackson
hard shut down
I dont know about pushing in the clutch cause I always have my clutch pedal depressed when I turn off my ignition. Mine use to shut down hard with the clutch in till I replace the clutch and got rid of the dual mass flywheel. Now it shuts down fine and I am real happy with the new clutch.
Old Sep 13, 2002 | 03:11 PM
sud z's Avatar
sud z
hard shut down
Charles Bearden
Escape & Escape Hybrid
May 31, 2017 08:24 AM
mike L
Electrical Systems/Wiring
May 9, 2017 02:28 PM
DKluke
Dec 6, 2016 03:09 PM
bigbubba87
20
Oct 10, 2012 06:55 PM
vervepipes
Jan 20, 2011 12:21 PM
