Engine still running after...
Old Sep 14, 2002 | 09:48 PM
rvfiver's Avatar
rvfiver
Recently, and only once in a while my engine continues to run after shutting off the ignition and removing the key. It will shut down only after cycling the ignition switch a second time. Anyone else having this problem? Now that I am 2000 miles out of warranty I shutter to think of what the dealer will charge me to find and fix the problem. Thanks for any help.
Old Sep 18, 2002 | 05:32 PM
harryball's Avatar
harryball
Do you have the Ford Alarm/Autostart system installed?
If it's stock I have no idea, other than the truck just loves to run.
Robert
Old Sep 18, 2002 | 06:35 PM
rvfiver's Avatar
rvfiver
Negitive, no autostart system installed. I have noticed that I do not have to cycle the ignition switch as I mentioned in my first post to get it to shut off. It shuts off by itself about 5-10 seconds after I turn it off and remove the key. It's now doing this more often than I first mentioned. Any other ideas?
Old Sep 18, 2002 | 08:11 PM
gseeders's Avatar
gseeders
If it's not to much trouble disconnect the after market goodies that you have installed to see if maybe you have tapped into a wire that you shouldn't of.
I have a turbo temp monitor installed on mine, pull the key and walk away and when she gets to 300, it shuts down.
I have heard other types you can set the time to shut down!?
Did you add your goodies or buy it that way? Did you do the installation?
just a thought!
over and out
Old Sep 18, 2002 | 11:31 PM
c_nate's Avatar
c_nate
