synthetic oils
Old Apr 24, 2004 | 08:45 AM
  #31
Choctaw Bob's Avatar
Choctaw Bob
Originally Posted by Mud Doc
Don't know why anyone who does their own oil changes wouldn't have one of these valves--mine has the nipple to put a hose on and can easily direct oil to a container without a funnel. No drips, no mess.
By the way, I have a 350, not a 340 as I said at first. Surprised no one hung me out to dry on that one.
No flamers here. We try to limit things to technical arguments only.
I appreciate the valve link NiNjADoC. Even a genius like me can't know everything! I ordered the valve this morning. I had seen similar valves but most trucks I've owned before have been slammed so not enough clearance for such gadgets.
Thanks again for the neat gadget
Old Apr 24, 2004 | 08:52 AM
  #32
Choctaw Bob
Originally Posted by johnsdiesel
The .95 from the HP reservoir is not included in the 15 quarts. Same thing with the 7.3 from 1999+. They listed the refill capacity at 15 quarts knowing you wouldn't drain the HP res. Some guys do it on the 7.3 which is why I was wondering if it was practical. So, your actual oil capacity is supposed to be 15.95 quarts, but the refill capacity is supposed to be 15 quarts. That's why I brought up the issue about only being able to drain 13.5. Therefore, if you're really running 15.95 quarts you're leaving almost 2.5 quarts in the engine at oil changes.
I can't explain the discrepancy. I only know that a 14 Qt. fresh oil change with filter puts the oil slightly over the full mark on the dipstick on my truck.
Old Apr 24, 2004 | 11:34 PM
  #33
dbm04F250's Avatar
dbm04F250
The quick drain valve would probably be a good item for some but I use my truck offroad hunting and such. I don't want to take the chance of having the thing knocked of in the middle of nowhere. Besides, I really don't mind a little bit of oil on my hands to get a regular inspection of the magnet on the drain plug.
Old Apr 25, 2004 | 12:08 AM
  #34
Choctaw Bob
The same thing concerns me.
Old Apr 25, 2004 | 12:10 AM
  #35
thunderbird's Avatar
thunderbird
I wonder with 13.5 quarts of mobil delvac 1 5w40 the pilot inj. would work again ? That is with the proper re-flash.
Old Apr 25, 2004 | 07:52 AM
  #36
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
What happens if someone did not really like you and drained out 10 quarts?
Seems very easy to me....
There I go not thinking very much of the human race.
Is there a way to lock it, guess drill .060 hole and safety wire it
Would not be hard.
Old Apr 25, 2004 | 09:17 AM
  #37
Choctaw Bob
Would not be hard.
But then it would be easier to remove the plug!
redrivergorge
Feb 11, 2013 08:33 AM
04mudslinger
1997 - 2003 F150
Mar 29, 2012 07:31 PM
changoo
2004 - 2008 F150
Dec 4, 2010 06:25 PM
nebmike
Jan 17, 2008 06:32 PM
Strjock81
Jan 3, 2004 08:34 PM
