truck sputters
Old Sep 26, 2004 | 07:04 PM
ford5.8's Avatar
ford5.8
Because its the only logical thing that I can think of that makes sence..Do you have any other ideas?
Old Sep 26, 2004 | 11:06 PM
broken wire's Avatar
broken wire
I believe most of these symptoms are ignition related to the sparkplug cable routing, for the 5.0 I know for sure, look at the firing order, 15426378, notice 7 and 8 is left bank and 7 fires into 8 through electromagnetism, if the cables are not laid in a Ford harness properly they can crossfire and cause a missfire at low rpm any speed, taking the #8 cable out of the harness and moving it up to the intake plenum area gets the 7 and 8 away from each other and the missfire goes away, I believe 5.8 have the same problem but on the right bank. Broken Wire
Mudslinger72315
2004 - 2008 F150
Sep 7, 2024 07:56 AM
MisterRanger
1983 - 2012 Ranger & B-Series
36
Jan 12, 2016 11:26 AM
StlNavyGuy
Jun 15, 2012 07:34 PM
dencrawford
May 2, 2012 11:05 AM
rg200amp
Apr 21, 2008 05:51 PM
