460 timing cover installation
Old Apr 22, 2004 | 01:55 PM
someday's Avatar
someday
i have an 89 that i have to replace the timing cover gasket and i can not figure out why i would need an alignment tool to put the cover back if i just put it on and tighten the mounting bolts. shouldn't the bolts align the cover? am i missing something and if it is really necessary where can i get the tool
thank you,
mark
Old Apr 23, 2004 | 01:39 AM
Superdave's Avatar
Superdave
You can use the spacer behind the dampner for the alignment tool.
Leave the cover bolts a little loose, slip the spacer on the crank then into the seal on the cover, then tighten the bolts.
Thats what you would be doing anyway, aligning the timing cover to match the spacer, so it would ride in the seal properly and not cause a premature seal failure.
Old Apr 23, 2004 | 03:41 PM
someday's Avatar
someday
now it makes sense.
Old Apr 23, 2004 | 03:43 PM
someday's Avatar
someday
should i use a special grease for the seal or engine oil?
Old Apr 23, 2004 | 08:52 PM
tmyers's Avatar
tmyers
Guys I have tried 4 times to get a good alignment using the spacer. So far it never fails that I end up with a leak within 1000 miles. Does anyone know where I can get an alignment tool for this job. I'm getting tired of this operation. Thanks.
Old Apr 23, 2004 | 10:28 PM
greenhighboy's Avatar
greenhighboy
Are you sure your leak isn't around the outside of the seal? I always put a light coat of silocone on the ouside edge of the seal. You could also be getting the wrong seal for your timing cover. The spacer is the best alignment tool because it is what the seal will be running on.
Old Apr 24, 2004 | 09:22 AM
mchild's Avatar
mchild
Terry,
Since you are going to have to remove the timing cover again anyway, after doing so check the crank where the seal rides to make sure it is not grooved. Any groove will allow a leak. If it does have a groove there are sleeve kits that will fix it. As others have said, the spacer is as good an alignment tool as there is so it is probably not an alignment problem. Before you remove the cover again you may want to clean the area thoroughly and then keep a frequent eye on it to see exactly where it is leaking. Since the timing cover is aluminum make sure there isn’t a crack in it.
Good luck,
Mark
Old Apr 26, 2004 | 01:43 AM
Superdave's Avatar
Superdave
Use engine oil on the seal surface.
tmyers
Are you using a sealer between the outside of the seal body and the timing cover?
I have used this method ( using the spacer for the alignment tool ) three times on different 460's and never had a leak. I put a light coat of Permatex # 2 on the outside of the seal before installing it in the timing cover.
BTW, the seal rides on the spacer, not the crank on a 460. Yes there could be a wear groove cut into the spacer causing a premature leak. A repair sleeve can take of this for you if it is the case.
Old Apr 26, 2004 | 09:10 AM
mchild's Avatar
mchild
Superdave you are correct. Don’t know what I was thinking. And that makes it even easier to check to see if a groove is causing the leak. Don’t have to pull the cover just the spacer.
Mark
TheDudeAbides
Mar 7, 2017 05:28 PM
MTf100
Mar 31, 2016 01:15 PM
akamacgyver
Jul 10, 2014 02:51 PM
iam me
Jan 3, 2010 09:37 PM
Jim88554
1997 - 2003 F150
Nov 17, 2008 05:39 AM
