increade in gas mileage
Old Apr 22, 2004 | 10:51 AM
kodeman05's Avatar
kodeman05
does anyone have any suggestions to increase gas mileage. i have a 1996 explorer v6 and i average around 7-9 miles per gallon city and about 13 highway. i would appreciate any help. thanks in advance.
kody
Old Apr 22, 2004 | 02:31 PM
CobraXP's Avatar
CobraXP
How many miles do you have on it? When was the last service done? There are many things that can affect your gas mileage. Doing a regular tune-up - spark plugs, wires, cleaning the IAC, mass air sensor, an oil change, etc. Also, make sure your tire air pressure is correct and you have a front end alignment. All these items can cause bad gas mileage.
Old Apr 22, 2004 | 04:47 PM
jclj2003's Avatar
jclj2003
you could get an intake and exust done and get a chip
Old Apr 22, 2004 | 08:20 PM
mustangsvt's Avatar
mustangsvt
wow man....thats like what my mom was getting with a dirty as **** air filter...change your air filter!
also do your oil changes as shown in the manual...
Old Apr 22, 2004 | 08:32 PM
Jever's Avatar
Jever
I would start with a basic tune up. Plugs, wires, filters, everything. Also try running a higher grade of gas. That helped my tremendously.
Old Apr 24, 2004 | 01:07 AM
kev100's Avatar
kev100
After replacing plugs with some good plats....some good plug wires (don't skimp on either of these).....changed fuel filter.....etc.....I started getting original mileage on a 130K+ Exp. 98 SOHC 4.0. (around 20 mixed driving...higher if all hiway).
Plus....go EASY on the gas....don't leadfoot...makes a HUGE difference with Exps.
Old Apr 24, 2004 | 01:54 AM
Blly177's Avatar
Blly177
air filter
fuel filter
plugs
wires
pcv valve
o2 sensors before cats
clean maf
clean fuel injectors
sea foam
