97 Thermostat Question
Old Apr 22, 2004 | 10:26 AM
Rikc1's Avatar
Rikc1
Question 97 Thermostat Question
Long time reader, 1st time writer. Need some info on thermostat for a 1997 Powerstroke used for pulling 5th wheel. I recently lost the waterpump in the Driveway--How lucky is that?? But anyways I'm about to install the new pump and want to replace all the fixin's that go with that. Question is any need to change from stock temp?? Also I know in the past older 6.9L & 7.3L's should stay with the IH thermostat, is it o.k. to go with other than motorcraft on the powerstroke??
Thanks
Old Apr 22, 2004 | 06:00 PM
Quadzilla's Avatar
Quadzilla
The best move is to go with a 203* thermostat. Unfortunately, they're only available through one place, Dieselsite.com. Your truck will run better, and give slightly better mpg.
