351m problem
Old Apr 22, 2004 | 09:01 AM
tinman213's Avatar
tinman213
351m problem
Hello everyone. I have a problem and I'm not sure if this is the right forum or not. I have a 1979 F150 with a 351M. when the engine is cold it starts right up
and runs great. when the engine gets hot (about 20 minutes) it shuts down just
like I turned the key off. then it will not re-start untill it cools back down. It apears that the electrical system shuts down but I dont know. my manuals are
not much help and I really dont want to take it to the shop. any advise would be great
Thanks
Paul
Old Apr 22, 2004 | 09:11 AM
fmc400's Avatar
fmc400
MSEE
My first guess would be the plug wires aren't routed well, maybe they're resting on the manifold.
Old Apr 22, 2004 | 09:19 AM
fmc400's Avatar
fmc400
MSEE
Another likely thing to look at is the ignition module - might be on the inside of the fender. They're known to fail when they get hot.
Old Apr 22, 2004 | 10:04 AM
ddfunnyfarm's Avatar
ddfunnyfarm
Here is another vote for the ignition module. Another possiblity could be the pick-up coil.
Good luck and let us know.
-Di
Old Apr 22, 2004 | 10:55 AM
tinman213's Avatar
tinman213
I did change the module, plug wires are fine, and it still does it. Thanks for the input. Any other suggestions?
Old Apr 22, 2004 | 11:08 AM
Brian77Ford's Avatar
Brian77Ford
Check the horseshoe looking part that goes on the coil.My truck did the same thing.I was trying everything and nothing worked.I wilgled this piece,and vavoom,it started right up.That part is a dealer or junkyard part only.It cost $9.00 but worth every penny because it worked.Just a thuoght.
Old Apr 22, 2004 | 11:50 AM
fmc400's Avatar
fmc400
MSEE
Might as well check over the entire coil while you're at it. Maybe it's getting too hot and can't hold the current.
Whatever the case is, it sounds like it's a complete cut off of electricity, rather than something slowly losing power. You said your engine shuts right off like you turned the key off, rather than the engine missing or sputtering until it kills.
Might end up havin to go through the whole engine electrical. =(
Old Apr 22, 2004 | 07:55 PM
FordCardinal's Avatar
FordCardinal
Check the electrical module. (Brain Box) There is a circuit within it that is designed to switcht the electrical current over when it is no longer needed. If this wears out then the engine will just turn off.
ford5o
Sep 11, 2016 03:55 PM
Barrakuda
May 25, 2016 04:52 PM
Joe Andre
Oct 9, 2015 10:01 PM
lifted88bronco
1978 - 1996 Big Bronco
16
Jan 2, 2006 03:40 PM
RomeoAlphaYankee
Mar 23, 2003 10:43 PM
