Having Problems Taking Off Fuel Filter
Old Apr 22, 2004 | 05:55 AM
princealbert27534's Avatar
princealbert27534
Arrow Having Problems Taking Off Fuel Filter
I have an 03 Ranger with the 2.9. The filter with three hoses and the new clips . I have herd you can get them off with a small flat head screwdriver but i need more detailed instructions cause Ive tried it and got nowhere.Iwould really appreciate any suggestion anyone might have.
thank you
Old Apr 22, 2004 | 07:27 AM
G2IC_Wraith's Avatar
G2IC_Wraith
Most of these clips are the same from year to year. By "new clips" do you mean they look like a flat triangle with two legs comming off the bottom. The end of the hose has 4 holes in it so that when you push the legs through the first 2 holes the end of the legs comes out the other two. Yes, a flat head is your best freind, or needle nose. If you can stick the flat head under the triangle end with one hand then use your other to push up on the legs sticking out the other side. That way you don't break them by prying up to hard. They should just pull out from that point.
Edit (5 sec later): I always forget to notice that some of these are user's first posts. Welcome to FTE.
Old Apr 22, 2004 | 08:34 PM
princealbert27534
they look as though they are round with one flat end that holds it in . On one side it has the clip clearly visible and the other has two small square holes. It looks as though if i could expand the ring i could easily get it off. I was wondering if there was a special tool to take them off . But i was more or less trying to find an easier and cheaper way to do it rather than having to buy a special tool. I know of the old style where you can easily take them off with a flat head screwdriver and the clips are more of a U shape but these new ones have to be something so the dealer can make more money or something.I have definately confirmed the year model of the truck to be an 02 and I have the new filter it comes with the bracket and all but no clips so there must be a way to get them off with out getting mad and breaking them which is what i may do if i dont watch out.i would appreciate any help i can get. thank you very much.
Old Apr 22, 2004 | 08:38 PM
99 ranger bob's Avatar
99 ranger bob
I would go to my local napa they have a book with every tool known to mankind in it that you can get if theres a special tool for this application they have it or can get it
