E150 universal chair removal
Old Apr 22, 2004 | 03:36 AM
stef1957's Avatar
stef1957
I just bought a 1993 ford E150 universal conversion van and would like to be able to take out the seats temporarily to load with cargo. I looked at my ford manual and thought it had an easy release on the back captain chairs but they are totally different than ford's and where it looked like there was a pin to release so the pedestal will slide off I can't get the chair to budge when I pull, pry, even hammer, the pin. The bolts underneath the van have no head and spin when I try to take these out. Universal is out of business, Ford says they don't know how to take the seats out since they didn't do them, and I'm going nuts with what should be an easy thing to do. Has anyone had this problem? The bench seat would slide right out no problem except you have to take out the captain chair pedestals to get it out the side door. thanks
Old Apr 22, 2004 | 07:59 AM
packlet's Avatar
packlet
if the pedestal bolts are loose enuf to spin, you may be able to get a pair of vice-grips onto the heads under the van, which ought to allow you to remove the nuts from inside... otherwise just drill them out and replace with new bolts and big wing nuts from the hardware store... good luck. btw: is your rear door not open-able to get the bench out?
Old Apr 22, 2004 | 09:49 AM
hanno2s's Avatar
hanno2s
Might be easier (and more of a mess) to just grind the top of the bolt off. Whats left falls to the ground, seat is loose.
annaleigh
Nov 9, 2015 02:48 AM
WarrensE350
Sep 24, 2015 11:13 AM
Phonmann
Jul 10, 2014 02:21 PM
RRS540
Jul 30, 2010 10:22 AM
OldGlow
17
Dec 7, 2009 06:17 PM
