Security Devices
Old Apr 23, 2004 | 08:13 AM
purplewg's Avatar
purplewg
Originally Posted by ZBeeble
Well driving a truck helps. I work in downtown Toronto ... and the metermaids are fairly bullish there. Problem is... when you're hauling several thousand pounds of stuff, you don't want to park down the street to unload.
With 4 wheel drive and a 7000 lb curb weight, a super duty truck isn't something the little tow trucks can pick up easily. Problem is that they have to get all 4 wheels off the ground... and the common tow truck in the fleet that patrols downtown isn't rated or equiped for it. They just refuse, if asked.
They can always call for a bigger truck, but most larger tow trucks can make more money doing real work ... and by the time they get downtown ... you're gone ...
Yeah, I had a 94 F250 4x4 7.3L Heavy Duty towed because I lost a clutch while on vacation. Another 94 F250 flat bed wrecker picked it up and took me to the nearest Ford dealer with no problems. Most are flat beds here in FL now.
Old Apr 23, 2004 | 09:55 AM
Tadashi's Avatar
Tadashi
Thanks. I understand nothing is theft proof but I am gonna make it a PIA to take.
Old Apr 24, 2004 | 12:51 AM
BJ_Hawk's Avatar
BJ_Hawk
Tadashi,
Been here at Bliss since last Nov and heard of several trucks making the run for the border! All types and brands; when I got the SD I had a maxi-lock installed. A keyed switch under dash that disables the starter and pushes a cable pin through a latch in the hood to keep it shut. It was recommended over the viper alarm system by the EPD. Two of the peace officers had trucks attempted to be truck jacked and the viper made it's way to Pancho Villia's homeland the other damaged but still stateside. When I had the remote lock system installed by ford it too disengages the starter. Maybe over kill, but the truck is still here. Are you headed here for the SMC? If so, let me know and I'll help you all I can. Later
BJ_Hawk
Old Apr 24, 2004 | 06:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Has anyone done the hidden switch that kills juice to the ignition?
If so which wire and where?
Old Apr 24, 2004 | 10:39 AM
BJ_Hawk's Avatar
BJ_Hawk
Tim,
not sure here, but the maxi-loc kills all power to the starter. Turn key and every thing happens that should until you turn to start and there is no starter action. The switch is a keyed housing up under the dash. I did not install it, but looks fairly simple. It also secures the hood. Hope this helps.
BJ
Old Apr 24, 2004 | 09:22 PM
IB Tim's Avatar
IB Tim
It sounds like, what I have been looking for.
Old Apr 24, 2004 | 11:49 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
I have an '03 Excursion Ltd. 6.0LPSD 4X4 and I have no idea if I have PATS??? Never read about it until now (don't feel bad Tim... you just happended to ask before me)!!!
1) I have the memory seats.
2) No memory climate control (never heard of this option).
3) I have adjustable foot peddals
4) PATS????? (I do not know)
Thanks,
Jeff
Old Apr 25, 2004 | 07:20 AM
IB Tim's Avatar
IB Tim
Makes you think that we worry so much about our trucking continuing to run we do not even know what options we have. Can you imagine how many prayers are said every night accross this country for the 6.0….
sad, sad, sad
Old Apr 25, 2004 | 10:20 AM
Tadashi's Avatar
Tadashi
Hawk - thanks. I will look into that. I am headed to Bliss around this July. Still looking for a house before we hit post.
beachbum - if you have PATs your keys are big and thick (plastic handle part). If you need a replacement it costs about $40 per key. You cannot just have a key made anywhere it has to be ordered from Ford.
Old Apr 25, 2004 | 10:26 AM
jdadamsjr's Avatar
jdadamsjr
Tim,
I say prayers - not as many as I should...
but NEVER about my truck !
no problems with it, and not high on the priority list if I did have nay...
Old Apr 25, 2004 | 10:42 AM
Txfodiesel's Avatar
Txfodiesel
Also, if you have the pats, of any kind, your insurance rates drop drastically.. State farm gives BIG discounts on it here in ft.worth..
Old Apr 25, 2004 | 12:53 PM
jdadamsjr's Avatar
jdadamsjr
Hi there Txfodiesel from greater downtown Mansfield form another all black truck, although an Ex :-)
There's a plan afoot to get together at Texas Raceway in Kennedale - 1/8 mile trip in a nice seeting --- sounds like fun...
will keep you posted:
http://www.texasraceway.com/
Old Apr 25, 2004 | 02:56 PM
  #28
IB Tim's Avatar
IB Tim
I just throw it in at the end of the list
Never hurts to pray for a bit of safety
Don’t quit in the intersection with 10K behind you.
Old Apr 25, 2004 | 08:56 PM
  #29
Tadashi's Avatar
Tadashi
Hawk can you give the company and full name of the maxi-loc? If you have one a web site for more information. I am having a tough time finding it.
Old Apr 26, 2004 | 01:25 PM
  #30
kallen506's Avatar
kallen506
PATS on '04 F250 Harley
The Harley 2004 F250's do have the chip on the key like everyone is discussing was not an option on Superduty series. I had an alarm with remote start installed, and they did have to get another RF'd key to install in the dash for the remote start. They did not cut the key, just using it for the RF connection. They tapped into the steering column for all the necessary connections to the starter kill, power, etc... I have been happy with it so far. My seat controls and everything else works. I too wish the climate control was an option on the 2004's, but it sounds like the 2005's will have it.
Oh well, must my $.02.
