Brakes let go!!
Old Apr 21, 2004 | 09:33 PM
kcwsafd's Avatar
kcwsafd
Brakes let go!!
I have brake problems with my brakes 94 250 7.3 turbo 125k
ABS light on and off, pedal feels funny, sometimes hard sometimes soft, the biggest concern is the feeling of letting go when stopping from highway speeds, almost like a jake brake disengaging started all of a sudden . need help any ideas??
Old Apr 22, 2004 | 10:20 AM
Al_V's Avatar
Al_V
Uneducated wag: ABS control system.
Old Apr 25, 2004 | 11:16 AM
jkhawk10's Avatar
jkhawk10
My abs light was on occasionally and then stayed on,braking was soft/slow inconstant. Found the rearend was failing-over1/8" side play in yoke,metal chuncks on drain plug and the abs sensor that bolts in top of diff had the end eaten off by the internal gear-probably drove it 1800 miles while it was failing-never heard it over engine and tire noise.Was at 130,000 miles.91 F-350 srw 4x4 never even opened it up, found a limited slip rear in wreaking yard for 400.00
Old Apr 25, 2004 | 11:55 AM
butch a 250 d's Avatar
butch a 250 d
i have a 94 250 4x4 idi non tubo and i was under the impersion that pice on the diff case was the speedo sensor hope one of you guys can set me straight
butch
Old Apr 25, 2004 | 09:42 PM
jkhawk10's Avatar
jkhawk10
I was talking about rearend not transfer case.You will see a abs sensor bolted into top fwd of the center section,its the only wires going to your rear differental.The abs and speedo sensors are different,speedo is in t-case.
Old Apr 25, 2004 | 10:18 PM
butch a 250 d
i wll have to look on my t case ? cause when my speedo act up i pull that sensor out of the rear end and clean it and my speedo works fine agian
hope some can set me right
butch
Old Apr 29, 2004 | 07:21 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
with my truck the brakes went that way, sometimes they would work sometimes not(kinda scary when there is a brick building in front of you the first time this happens), it was my vacuum pump
