5) 4x4's should have 31 spline axles.
4) 4x4 should have a different pinion angle because they usually sit higher.
3) ???????????
2) ???????????
1) ???????????
I don't know exact measurements but the frames on the F150s from 73 to 77.5 were wider than the 250s, or more acurately the 73-77.5 F250's had a narrower frame than the rest. The axles themselves should be no different in width but the spring perches on a 73-77.5 F250 should be a little narrower than an F150 or a 78-79 F250. Perches can, of course, easily be removed and relocated and pinion angles can be adjusted at the same time.
