bad idle ranger
Apr 21, 2004 | 06:44 PM
bad idle ranger
I have a 1996 4x4 4.o liter with 99,500 miles it idles rough even after i changed plugs wires and used fuel injector cleaner , what am I missing?
Thanks for your input.
Apr 21, 2004 | 07:16 PM
Have you changed the air and fuel filters? Also check for vacuum leaks.
Apr 21, 2004 | 07:27 PM
air filter is new and i assume that since i have enough fuel pressure to run at highway speed i think it should be ok. is there a way to test for vacuum pressure loss?
thanks again.
Apr 21, 2004 | 08:12 PM
idle position sensor
take the idle position sensor of and clean it with some achol and q tips. it is on the top of the throttle body.
Apr 21, 2004 | 08:16 PM
Um, the IAC solenoid. I've found carb cleaner is quite effective for this.
Apr 21, 2004 | 08:21 PM
ok gentlemen I'll give that a shot ,
i appreciate it.
Apr 21, 2004 | 08:27 PM
where is the IAC solenoid located exactly?
Apr 22, 2004 | 01:50 PM
Check out the link on the 4.0 IAC in the tech info thread at the top of the forum, Rockledge has a pic of it from his truck.
Apr 22, 2004 | 07:52 PM
OK , thanks , is there any chance it could be excessive carbon build up in the intake ?
Apr 23, 2004 | 05:55 AM
Carbon build up should not cause poor idle.
Apr 23, 2004 | 10:15 AM
Could be the screen on your fuel pump as well...not letting anough gas thru at idle speeds. It could also be your EGR Valve, buddy on mine had same type of prob on a 96 3.0L 4x4 and the EGR valve had actaully broken away from the manifold due to rust.
90pioneer
6.4L Power Stroke Diesel
Nov 29, 2019 08:32 AM
Stan's 04
1997 - 2003 F150
Feb 7, 2011 09:02 PM
CJK440
1997 - 2003 F150
Jan 31, 2006 01:08 PM
881504x4
Mar 2, 2005 08:32 PM
