Current Recalibration Code for 6.0L Owners?
Does anyone out there know what the current recalibration code is for the 6.0L diesel? Has there been an updated one since Oct. of 2003? I have an 04 6.0L PSD built on Sept. of 03. It was flashed in Oct. of 2003 and my milege went up unlike everyone elses seeming dropped. Topped out at 19.2 highway. Has dropped lately here to 13.4 on the highway. Dealer says there is a new recal code since october of 03? Is this true, orf are they filling me full of BS? My truck is a 6-speed not a torque shift 5 speed. So I would think it would be an entirely different program wouldn't it? I know the automatic's idle alot lower.
Built To Last, Built To Kick Dodge's A$$
2004 F-350 CC, LB, Fx4, 6.0L, 6speed, Black, Sunroof, Tinted Glass on all windows, 6 disc, polished aluminums, 285 BFG AT's, 4inch straight thru exhaust with a ITP 6 inch tip.
See http://www.flatratetech.com/6literpo...l_updates.html for a complete listing of flashes and what they include.
PAN,
Need to follow the link that SBV45 posted to determine which flash you need. Correct flash is based on enging build date. Engines built 09-28-03 and before are 03 engines, engines built 09-29-03 and after are 04 engines. The flashes are different.
This flash is only for 04 engines built 09-29-03 and after.
There has been only one flash for the 04 motors but, there are eight flashes for the 03 motors (built 09-28-03 and before). Last 03 flash was in December 03.
You need to check your engine build date sticker located on the FICM left valve cover at firewall by degass bottle.
Hope this helps
From Fordtech1, B29.6 revision 1/30/04
Hope this helps
Originally Posted by desertracer
Don't do Dec. flash if you want engine braking in 4th & 5th gears.
