how high to rev a PSD?
Old Oct 4, 2002 | 08:27 AM
dcmsu's Avatar
dcmsu
I just test drove a 6 speed PSD the other day...and was wondering how high of RPMs I should go before shifting. Under normal driving and under heavy acceleration or towing? I am not sure what gears this truck had in the axles, but it was running about 2000 rpm at a little less than 70 mph. This seemed kinda high to me...I guess it just needs bigger tires.
Dan
Old Oct 4, 2002 | 10:19 AM
Cope's Avatar
Cope
I guess just cruising through town I shift somewhere around 2000 or so. When accelerating hard or towing I shift at about 3000. This, of course, is only after the truck is properly warmed up. I wouldn't worry too much about over-reving. That's what the rev-limiter is for.
-Cope
97 F-350 PSD ZF 5 Speed 4x4
Old Oct 4, 2002 | 05:13 PM
The Diesel Dude's Avatar
The Diesel Dude
The PSD has an electronic governor that won't let you over rev it.
Old Oct 5, 2002 | 11:32 PM
hitecdan's Avatar
hitecdan
Old Oct 5, 2002 | 11:33 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Navistar rates the PSD for 4400rpm continious duty. Ford's factory rev limiter is 3400rpm. You can't over rev it.
The gears were either 3.73's or 4.10's
