Offroad & 4x4
mini spool
Old Apr 20, 2004 | 02:28 PM
fordman300's Avatar
fordman300
mini spool
are any brand of mini spool better than another, and how much should i expect to pay. Im puttin it in my Dana 44 front when i put the lift on (probably not till the end of may) i was just trying to get all the parts ready. i know ill have to put a spring in the slip joint but is there any thing else i should do. Should i replace the cross shaft while its out or should it be alright.
Thanks
Fordman300
Old Apr 20, 2004 | 02:49 PM
fishmanndotcom's Avatar
fishmanndotcom
you outta save the money and just weld it! other than that I can't help you. I have alwasy welded my gears and never looked back!
-jason-
Old Apr 20, 2004 | 02:51 PM
Idiomaticman's Avatar
Idiomaticman
i did a mini spool. its really easy. do a search under my name and you will find everything you need to know about the mini spool.
i bought a yukon gear mini spool, it works really well. be prewarned though, you will break axles and Ujoints. i did, after only 2 months and 5 trips out.
Idiomaticman
Old Apr 20, 2004 | 02:58 PM
highboy1975's Avatar
highboy1975
anyone think i would have problems putting a spool in a d60 with breakage?
Old Apr 20, 2004 | 03:29 PM
fishmanndotcom
Hell naw! like i previously said my front is welded and I run 39.5 IROK's and I give it hell! Never been broken! the only thing you would ever need to be worried about is your stub shafts and your 30 spline hubs! other than that it is a very stout front end.
-jason-
Old Apr 20, 2004 | 04:02 PM
proeliator's Avatar
proeliator
Front? Rear? What size tires? How much hp? What driving style? Rocks, mud, street? Well, you get the idea.
Old Apr 20, 2004 | 11:43 PM
82F100SWB's Avatar
82F100SWB
If you're planning on spooling your TTB front, just weld it, if you're gonna be hammering on it, you're just gonna break it anyhow, no sense wasting money on it...
I can bet that you will start blowing inner pass. side u-joints if you go to 35's, or attempt the front wheel burnouts indicated by your signature....
illinois4by
Jan 4, 2009 07:43 AM
Jrock909
Jul 19, 2006 01:35 PM
mdjohnson
Feb 4, 2006 10:52 PM
82f1504x4
Offroad & 4x4
18
Mar 12, 2004 03:27 PM
nolanc2
Apr 24, 2003 06:10 AM
