diesel problems please help!!!!
Old Mar 9, 2002 | 05:21 PM
stepside's Avatar
stepside
i have an 1989 diesel ford it used to have some oil
in the radiator now it can't hold much water at all
the last time i drove it diddn't have that much power
i let it warm up for about 10 min i drove it to the
store about mile away it died all of suddenden it stared
right back i looked back the whole plarking lot was almost
filled up with smoke.i cheaked the raditor it had no water
in the raditor i think it poured all the water into the piston
cylinder i think it has a crack head or blown head gasket i'm i
right has anybody else had this problem if so what did you do
or how did you fix it please help!!! JED
Old Mar 9, 2002 | 05:41 PM
powerstroker250's Avatar
powerstroker250
My bro-in-law had an 86. It had a cracked head AND a blown head gasket. Both of these seem to be common problems on the 6.9. Cracked heads are NOT repairable. We had to locate a new set.
Les
Old Mar 12, 2002 | 09:27 AM
curmudgeon's Avatar
curmudgeon
Post diesel problems please help!!!!
[updated:LAST EDITED ON 12-Mar-02 AT 10:31 AM (EST)]His '89 would be a 7.3 and, yep, it's time for a top end job. You can get warranted heads for $635, freight prepaid ($150 core charge) at DIS. The good thing about the old IDI engines is this job is fairly manageable for someone with decent mechanical skills. All you need is a good shop, a good helper, good tools, and a patient spouse. Adult beverages and anger management classes wouldn't hurt.
Old Mar 12, 2002 | 03:00 PM
powerstroker250
[updated:LAST EDITED ON 12-Mar-02 AT 04:01 PM (EST)]I did this job start to finish in about 9 hrs with beer and one so called helper
Les
Old Mar 14, 2002 | 08:59 PM
curtismck76's Avatar
curtismck76
becareful if you were not overheating.you may have other concerns.these engines have one minor minor problem.if the truck has high miles and the cooling system has been neglected electrolysis can eat holes in the cylinders from the backside of the the cooling jacket.
Old Aug 8, 2002 | 06:31 PM
craterjoe's Avatar
craterjoe
Old Aug 17, 2002 | 07:37 PM
rjmcgee's Avatar
rjmcgee
Hey, F E Horse, start your own post and stay out of these guy's.:-X11
Old Oct 10, 2002 | 07:56 PM
bilder12's Avatar
bilder12
diesel fans ... the ih 7.3 diesel has an oil cooler that may be causing the problem with the oil in the radiator. If the head gaskets are out of it, the radiator will just empty out and not show oil there. The pistons making compression will pressurize the cooling system and push the water out. Whatchathinkaboutthat
Old Oct 11, 2002 | 10:03 AM
curmudgeon's Avatar
curmudgeon
7.3 oil coolers are pretty reliable. Once they are assembled and installed correctly they hardly ever fail internally except to clog up from neglected coolant. Since the IDI 6.9s and 7.3s have a history of head gasket problems, that's where I'd bet my money.
bocomojoe
6.7L Power Stroke Diesel
Jul 20, 2012 02:51 PM
napoleankjj2006
19
Jun 27, 2009 09:54 PM
kencad54321
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 23, 2004 07:30 AM
mjbesen310
2004 - 2008 F150
Dec 9, 2004 02:33 PM
