where is the modulator
Old Apr 20, 2004 | 12:26 PM
pvtranger's Avatar
pvtranger
Exclamation where is the modulator
Ok got the truck up on the rack and cannot find the heat shield or the vacuam modulator or the vacuam hose I need to pull off. I do have leaking trans fluid and blow by in the exhaust. I was hoping to have this fixed today! cananyone out there tell me why I can't see the heat shield or tell me what it is close to. I have a 93 4 cylinder 2.3 just two wheel drive so it should not be hiding on me right. Please help asap cause I would love to get this done today.
Thanks all!
pvtranger
Old Apr 20, 2004 | 03:39 PM
Txquadhunter24's Avatar
Txquadhunter24
If you've got a OD tranny which you should in a 93. give up looking for the modulator because you don't have one. The OD trannies are shifted by RPM's instead of vaccum like the non-OD C6's And C4's
Old Apr 20, 2004 | 04:25 PM
pvtranger's Avatar
pvtranger
No got!!
Thanks, I just went to the parts store and got a part for this at $26.00 I guess I can take it back. Are you sure on this? The Haynes manual says thers is one but I don't see it.
Old Apr 20, 2004 | 06:44 PM
rclarke's Avatar
rclarke
2.3 in a Ranger may have an A4LD transmission. The modulator is on the passenger side of the transmission just behind the pistons for the bands.
