Oil Change
Old Apr 20, 2004 | 08:32 AM
Thumper4995's Avatar
Thumper4995
Oil Change
Hey fellas. Dumb question coming at ya but I am going to change my own oil tonight. A friend of mine changed his oil in his PSD and only got about 9-10 quarts (including filter) out of it during drain. He stated that it was a quart low when he drained it. When he went to fill it, it took only 12 quarts (including prefilled new filter). I believe our owners manual states that they take 15 quarts. Is this correct. I am very curious as to why he got such weird numbers during his oil change. Any thoughts? What is the proper method of changing the oil in these beasts?
Old Apr 20, 2004 | 08:54 AM
powerstrokefreak's Avatar
powerstrokefreak
My Owners Manual Says 14 Quarts With Filter Change And That Is Full On The Dipstick. I Know A Guy That Works At Ford And He Says That They Pour A Quart Of Oil In The Filter Before They Spin It On. Not Sure If That Is A Necessary Precaution On Not, But That's How The Pro's Do It. He Also Said That It Is A Lot Less Messy If You Take A Screwdriver And Pound A Hole In The Old Filter An Let It Drain Before You Take It Of.
Old Apr 20, 2004 | 08:57 AM
jschira's Avatar
jschira
The filter will take 1-1/2 to 2 quarts. You have to pour slow and let it soak in for a few minutes.
The 7.3 PSD will take 14-15 qts. All day, every day. If your friend only put 12 qts. total in, then he did not get all of the old oil out.
And yes, loosen the oil filter and then poke a hole in the bottom to drain it before you take it off.
Old Apr 20, 2004 | 09:16 AM
johnsdiesel's Avatar
johnsdiesel
He must have a 1994.5. They only take 12 quarts of oil.
Old Apr 20, 2004 | 11:31 AM
TJC1989's Avatar
TJC1989
Mine is a 2000. I let it drain quite a while, both from the pan and the filter housing, and pump / suck out all the oil I can get out of the HPOP, and mine takes almost 16 quarts. I probably sucked about a half to 3/4 quart of oil out of the HPOP. Go figure.
Old Apr 20, 2004 | 11:40 AM
85BigBlock's Avatar
85BigBlock
I was a supervisor at a Jiffy Lube, and when we changed the PSD it seemed that all the 7.3 filters took 1.5 quarts to fill and 14 quarts total(engine and filter)in the older body style(94.5-97) and 15 quarts total in the newer style(99-03). Make sure to use two hands to take off the filter, I've seen and had that old nasty diesel oil all over me and everything else.
Old Apr 20, 2004 | 11:47 AM
johnsdiesel
Except the 1994.5.
Old Apr 20, 2004 | 12:28 PM
wilbur996's Avatar
wilbur996
Got another dumb question for you guys. This is my first PSD and I bought it used and has no Owner's Manual. What is the recommended interval between oil changes? The truck is an 1999 E350.
Thanks!
Old Apr 20, 2004 | 12:30 PM
85BigBlock's Avatar
85BigBlock
Thanks!
personally I like 3000 or less but for the average person doing the average driving I wouldn't go over 5000.
Old Apr 20, 2004 | 12:34 PM
wilbur996's Avatar
wilbur996
Thumbs up
Thanks! I was thinking around the 5000 miles or sooner range. Sure is a lot of oil to change.
Old Apr 20, 2004 | 12:36 PM
85BigBlock's Avatar
85BigBlock
and a lot of $$$$$
Old Apr 20, 2004 | 12:44 PM
RedTaurus94's Avatar
RedTaurus94
Don't forget....that filter is a bear to get off without making a small mess when it is full of oil. I usually take a sharp object and poke a hole in the bottom of the filter, allowing the oil to drain out before un-screwing the filter. That makes it a little better, anyways. Personally, I'd like to know what everyone uses as a filter wrench. I can usually get the filter off OK, but I just don't think I am getting it tight enough on installation. The last time I removed my filter, it was WAY too loose for my liking. I know some people say they screw it down tight enough by hand, but I just can't seem to get that done for some reason. My last attempt at finding a GOOD tool was a strap wrench, but I hated it. I threw that P.O.S. in the trash after about two uses. Any good ideas? Surely there is a "special" tool out there somewhere that works well.........
Old Apr 20, 2004 | 01:16 PM
85BigBlock's Avatar
85BigBlock
There is a band wrench that is made for the PSD and the pre-PSD (fram filter # ph3766 and ph4875) I havn't seen them at the local parts stores but I would check out the quick lube distributers in the local phone book or on the net. or call one of the local quick lube places and ask where you could get one/order one.
Old Apr 20, 2004 | 01:55 PM
Craze's Avatar
Craze
Oil Filter Wrench
I've had a band type wrench for years that works great. It has a 3/8 drive hole in it for a ratchet.
Old Apr 20, 2004 | 03:12 PM
wilbur996's Avatar
wilbur996
I use the biggest pair of Channel Lock pliers they make. Works well for removing and installing. Who cares if you crush the filter a little bit on the removal. Just be gentle on the install and everything will be ok. Never had a problem with this method.
