Offroad & 4x4
changing ring and pinion
Old Apr 22, 2004 | 08:34 AM
Commo's Avatar
Commo
Originally Posted by tite4x4
Rebuilding the rear 8.8 is relatively easy if you have all the tools and info. I just got done rebuilding mine two weeks ago myself, putting in 4.56 gears and an ARB. Here is some helpfull sites that helped me:
[ The 4.56 gears would be okay for the 35's. If you do go with bigger tires, go with at least 4.88 gears.
Hey Title what did you take out of the 8.8?
I have an 8.8 in the rear with 3.55LS and the Dana 44 in the front.
I am thinking to go to 4.10 or 4.56. The guys ar Randy's told me that I would need new carriers except for the front since I plan on putting in a locker.
I am running 33's but may go to 35's.
Roland
Old Apr 22, 2004 | 09:42 AM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by threefiftyone
The lower the ratio you go, the weaker the gears become.
i've seen 5.13's pushing 44" TSL's with a Detroit locker and 450/500 hp! they seem strong to me!
-jason-
Old Apr 22, 2004 | 10:15 AM
rlh's Avatar
rlh
-jason-
You have seen this with an 8.8? 37" tires is pushing it with th 8.8 and the D44 with lockers on the 8.8. The stock axles would also be a big issue.
Old Apr 22, 2004 | 10:34 AM
fishmanndotcom
ooooooooo no i was talkijng about a sterling 10.25! sorry bout that, lol. when you order gears though if you order thick gears then they are stronger! i dunno if they make them for 8.8 or not though.
-jason-
Old Apr 22, 2004 | 12:30 PM
threefiftyone's Avatar
threefiftyone
Well fishman, in theory, the more teeth there are, the weaker the ring gear. They'll hold fine but you should go with a thicker ring gear like you mentioned before me.
Old Apr 22, 2004 | 05:02 PM
bremen242's Avatar
bremen242
Actually, I believe the real problem is that the pinion is really small and that is why is it weaker.
Old Apr 22, 2004 | 06:28 PM
tite4x4's Avatar
tite4x4
Roland
My rear was custom built about 4 years ago. Had the flanges that hold the drum brakes cut off. And the 9" flanges welded on. Then I had rotors mounted, 410 gears, and an Eaton limited slip installed. The Eaton basically desenagrated, chiping the pinion gear in the proces. I guese four years of abuse. BTW - the brackets that hold the calipers, Also, hold the axles in place. Thereby elemenating the C-clips inside the carrier.
Since you are planning on putting maybe 35" tires on, I would recomend the 4.56 gears. Also, the guys at Randy's is correct. Idon't remember what the #'s are, but I think it's like 3.73 and below use the same carrier as stock and 3.9 and above use a different carrier. When you go and place your order for parts, just go ahead and order the locker and gears at the same time. The parts person should be able to tell the differrence.
Old Apr 22, 2004 | 06:49 PM
rlh's Avatar
rlh
There is no carrier break in the 8.8 except for certain locker manufacturers. The D44 break is 3.73 and down or 3.92 and up. For clarification, the stock carrier and Trac Lok for the 8.8 has no breaks.
Old Apr 25, 2004 | 09:44 AM
77300i6's Avatar
77300i6
Question I have a 77 F-150 4x4x w/ a 300 6. I plan to run 35's on it-will 4.11's be a low enough ratio or would 4.56's be the way to go? It gets a lot of street use. Will I need to change the carrier for the 4.11's? Acually, it'll be 4.11's in the rear w/ 4.10's in the front since I can't seem to find 4.11's for the D44.
Old Apr 25, 2004 | 09:59 AM
fishmanndotcom
i got a buddy who has an 83 f-150 with a 300 and running 35" BFG's. he has not had any problems running 3.55 gears.
-jason-
Old Apr 25, 2004 | 10:20 AM
jimdonohue's Avatar
jimdonohue
Not sure how anyone can say replacing the pinion gear is relatively easy, you gotta have alot of tools, strenth, patience, knowledge, and determination. I darn near killed myself doing this to my 250
Old Apr 25, 2004 | 10:38 AM
tite4x4's Avatar
tite4x4
Well it does help when you have several friends to help with lunch and dinner as cheap labor. But having some good tools is very handy to have. Here are couple that may help out the next time you change gears.
Old Apr 25, 2004 | 01:11 PM
  #28
threefiftyone
Is a press a must-have item when changing gears?
Old Apr 25, 2004 | 02:36 PM
  #29
monsterbaby's Avatar
monsterbaby
yea it is pretty much a reuirement as almost all of the bearings are pressed on in about every rearend, and the more tools you have the easier it is. if you don't have a press or access to one you will probably have to take it to a shop, and payh them to do the pressing, and depending this could end up costing more than haveing someone just set up the rearend for you.
Old Apr 25, 2004 | 02:55 PM
  #30
Muddr Trukkr's Avatar
Muddr Trukkr
im running 5.13's through the 8.8 and d44 ttb to the 35"mud brutes with detroit locker in rear and posi up front, and shes holding up strong, my od gear is a tad weak, buti'll fix that up with some 37's
