Engine block heater
Old Oct 16, 2002 | 08:59 PM
jle249's Avatar
jle249
Engine block heater
How can I tell if my engine block heater is working on a 2002 PSD? I'm not having any starting problems nor do I really even need the thing in Dallas. Just wondering how I can tell since there is not a light or anything.
Thanks,
John
Old Oct 16, 2002 | 11:01 PM
Aaron S's Avatar
Aaron S
Post Engine block heater
When I plug mine in after about 10 seconds, I can hear the coolant boiling or something around the heater element.
Aaron.
2001 F250 PSD 6-SPD 4x4 SCMT Banks Monster Exhaust EGT, Boost, Oil Pressure, Oil Temp/Trans Temp Gauges
Old Oct 17, 2002 | 04:42 PM
Squiggy's Avatar
Squiggy
Engine block heater
Grab an Ohm meter and go to the positive sides of the plug with black and red, then test It should be between 20 and 30ohms.
Old Oct 17, 2002 | 05:41 PM
Brian02350's Avatar
Brian02350
Engine block heater
Please explain the block heater, I have a 2002 F-350 PSD, Where do you plug it in at? Does it come from the factory with one. I have no idea what you are talking about at all. It is begining to get cold here in N VA also. Explain please, Brian
Old Oct 17, 2002 | 08:18 PM
jle249's Avatar
jle249
Engine block heater
>please, Brian
The engine block heater is a heating element that generally installs into a freeze plug hole on your engine. It keeps the engine coolant warm making starts easier on cold mornings. It also makes the heater in the cab instantly warm. That is nice since we all know how long diesel's take to warm up. The plug will be found on the front end somewhere, if you have one installed. Its a standard 3-prong 110 male plug with a protective cap on it. Just plug it into an extension cord. Block heaters were not standard in 2002, but they are in 2003. The option price was only 30.00. You can get an aftermarket one pretty cheap also. I had to look all over the grill for mine and finally found it tucked behind the driver side fog lamp (Lariat).
Old Oct 17, 2002 | 08:19 PM
jle249's Avatar
jle249
Engine block heater
[updated:LAST EDITED ON 17-Oct-02 AT 09:21 PM (EST)]Thanks Squiggy!
Old Oct 17, 2002 | 09:16 PM
agm104's Avatar
agm104
Engine block heater
