Stumped!!!
Old Apr 20, 2004 | 07:28 PM
Dealford's Avatar
Dealford
Your lost signature is only as far away as the end of the cursor. Slide the cursor on to the word signature and presto it will show what's there.
This new format is really great! Pay real close attention to what happens when you move the cursor from place to place. Click on names etc., and the info becomes available.
My hat's off to all the folks that created this!
Old Apr 20, 2004 | 09:25 PM
FoMoCo_Rlz's Avatar
FoMoCo_Rlz
Oh no...don't remove that stuff. That would tremendously suck! It is a pain to get to, but it's not all that bad. Just start the pressure gauge line between the intake and valve cover opening. Then just reach around the intake track from drivers side and screw it on while looking down the fuel rail from front of vehicle to make sure you don't cross-thread it. I will take a couple of pics. Just tell me the easiest way to get them to you. As for my problem.......just dropped the tank. Wasn't as bad as everyone makes it sound. Maybe the pain is getting it back on. LOL! There is a rubber hose connecting the lift pump to the hard line. It was severely rotted and had a big slit in it. Filter sock had what was rotten in it. Getting pump tomorrow. Hope to have done tomorrow and no later than Thursday. I hope this is it.
Old Apr 20, 2004 | 10:04 PM
G2IC_Wraith's Avatar
G2IC_Wraith
FoMoCo_Rlz - pics would be great. I have my address turned on in my profile so I think you can send me a message that I can reply to. The hard part of the tank for me was the rusty straps. I had to cut them off, and then the long bolt in the back was the biggest pain. Getting it back up was no picnic either. The new straps were most iof the problem. I will try to reach it but my hand didn't really want to get in there.
Old Apr 21, 2004 | 11:14 AM
FoMoCo_Rlz's Avatar
FoMoCo_Rlz
I will get those when I get home. I have a bunch of print-outs from AllData, but I can't save, copy or paste, don't have a scanner, this sux. If you have a fax, I could probably use the schools to send that stuff to you. Do you have a fax number? I will take some pics of them and see how it turns out. Maybe that will work. Should be around 4-5 o'clock.
Old Apr 21, 2004 | 11:50 PM
FoMoCo_Rlz's Avatar
FoMoCo_Rlz
Fixed!!!
Just to follow up in case anyone was following this post, it turned out to be the lift-pump or the hose connecting the lift-pump to the hard line in the tank. The connector hose had a big slit in it. Both were replaced and now she purrs like a kitten. Thanks for all the replies.
