just a thought
Old Apr 19, 2004 | 06:49 PM
k85k03's Avatar
k85k03
just a thought
I was wondering if heads from a 302 would fit a 351W and the same for the intake? Thanks
Kyle
Old Apr 19, 2004 | 07:29 PM
Fordtech1's Avatar
Fordtech1
302 heads have smaller head bolt holes than the 351W, but a bolt kit is available to make the switch.
Old Apr 20, 2004 | 12:18 AM
mustange70's Avatar
mustange70
You can also have a machine (with the right tools this can be done at home) shop bore and tap the holes to the proper size, this will give you the strength of the larger bolts to. What year are the heads on the 302 and on the 351W?
Old Apr 20, 2004 | 06:08 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Just curious as to why you would want to switch?
Old Apr 20, 2004 | 12:19 PM
k85k03's Avatar
k85k03
the reason I would want to make the switch is because I have an 87 f-250 with fuel injection and it has the 302, then I have an 84 f-150 with a carbaratured 351W and I like the 250 alot more, and I would like to switch motors. I heard that the heads will fit and at the same time will give you a better compresion ratio? Thats why I was thinking about the swap?
Old Apr 20, 2004 | 12:21 PM
k85k03's Avatar
k85k03
the years: I have two 302's one is an '87 the other is a '69 the
The 351W I believe to be an '84
So will the intake swap out too?
Old Apr 20, 2004 | 11:54 PM
Fordtech1's Avatar
Fordtech1
351 intake is wider than 302 due to differing deck height.
bigswede
Kansas Chapter
Sep 18, 2013 07:11 AM
jimwilsonmasonry
16
Sep 24, 2012 08:49 AM
linkford
Nov 2, 2007 10:21 PM
bigbadwolfe
Jan 18, 2007 07:17 PM
jadel
17
Feb 13, 2005 10:38 PM
