Problem with heavy oil consumption.
Old Jun 21, 2001 | 04:12 AM
The Diesel Dude's Avatar
The Diesel Dude
Old Oct 21, 2002 | 10:23 AM
MFresh's Avatar
MFresh
Hi,
Am having problems with finding the cause of heavy oil consumption in a power stroke diesel. It is using about 1 quart of oil to every 80 miles.
Have changed injectors and new blower but didn't help. Exhaust doesn't show any problems.
Anyone have any ideas to cause and how to fix.
Thanks,
Mike
Old Oct 21, 2002 | 11:27 AM
The Diesel Dude
What year is it? How many miles is on it? Has it always done this or is it a recent thing? When you changed injectors did you use new O-rings and if so did you install them correctly? Do you have oil in the fuel (drain the fuel filter canister from the water drain into a glass jar and see if it is too dark to be fuel).?
Old Oct 21, 2002 | 03:52 PM
Johncos's Avatar
Johncos
If you jusy recently changed the injectors, than my quess would be the injector o-rings are to blame. This is a problem spot for a lot of older Powerstrokes.
