Superchips Powerstroke Microtuners On Sale
on
MotorHaven, the online store of Ford Truck Enthusiasts, now has
Superchips Powerstroke Microtuners on sale!
[link: motorhaven.autoanything.com/cgi-bin/Web_store/webshop.cgi?&product=superchips|Click Here!]
http://motorhaven.autoanything.com/Web_store/Images/TDIMT2001.gif
The Microtuner is the hottest new computer performance tuning product
from Superchips!
Tuning with the Ford Turbo Diesel Micro Tuner is very simple. Plug
the Micro Tuner into the vehicles ALDL diagnostic port, located
inside the vehicle. Every Ford Turbo Diesel Micro Tuner comes with
two different power settings; CARB certified "Standard Performance
Program" which yields a maximum of 60 horsepower and 115 lb/ft of
torque, and "Offroad Performance Program" which yields a maximum of
80 horsepower and 130 lb/ft of torque. Select which program you
would like to use, then select any available user options. Program
the vehicle with "Superchips Signature Tuning" in just a few minutes.
There's no need for tools, no need to access the ECU. Tuning the
vehicle is simple and straight forward. The Ford Micro Tuner 2001 by
Superchips Inc. is of a true plug and play design.
Suggested Retail: $419.00
Our Sale Price: $339.00
from Superchips!
on
>I was looking for a chip and have held off buying one since
>I was told that newer and better things are coming! Is this
>it? I do alot of towing and only have changed the mufler.
>Is this what I want? thanks.
This is the one from Superchips. Diablo is going to be releasing their Delta chip (already on order) which has its advantages too. Will its not at plug and play as the Microtuner, you can change programs on the fly (the one drawback to the Microtuner). Both are good products.
on
>Issues anyone? Will this be wise and effective on a 2002
>PSD?
>Also, can I put back the Factory original program with it?
>Robert
Yes, it will work well with a 2002. It will allow you to restore the factory program at any time (it stores a copy of the factory program in itself).
>PSD?
>Robert
OK, I ordered one. Hope I don't get taken :-)
I'll be towing a trailer with it so I plan to use the lower setting.
How important is it to have an EGT gauge and where do you put one? With the 2002 I have an intercooler (so I'm told) does that not help keep the turbo cool when using the tuners?
What else should I watch out for?
Robert
Robert
on
They make a BIG difference but they are not for everyone. Many people are happy with stock trucks. The Microtuner provides the same results as a chip but you get two programs for the price of one plus instead of taking 20-40 minutes to install it takes less than 2 minutes. Add to that the fact that you don't even need to know your ECU code and its a dream to install.
A few questions:
When I tow, it's less than 4000 lbs. Would I be safe to run the 80hp program, even though I don't have a EGT guage?
Also, the Diablo chip, and others, claim an increase in mpg. Does this unit also increase mpg?
Thanks for the information. This sounds like a great product.
Got my programmer,
I have no idea what this means:
"If your vehicle has not been returned to is STOCK program prior to service, The Superchips MAX Tuner will no longer be able to program your vehicle. Such a failure is not covered by the Superchips warrantee."
huh? Should I return the truck to stock any time I send it in for service or what? Plain English anyone?
