engine stall
Old Apr 19, 2004 | 09:49 AM
350wagon's Avatar
350wagon
engine stall
Cruising on the interstate when my van hits 75mph the engine seams to stall out until it drops right under75 ,other than that problem the van has plenty of power ,accelerates good,no misses ,idles smooth.any help or sugestions would be appreciated!
Old Apr 20, 2004 | 12:07 AM
c96drumm's Avatar
c96drumm
Welcome to FTE!
Did this just start or has it been doing it as long as you've had it? Kind of sounds like it has a governor in it to limit top speed.
BTW, it would be helpful if you would include a bit more info, such as year model, engine, transmission, how many miles.
Old Apr 23, 2004 | 01:11 PM
ken04's Avatar
ken04
The newer, fuel injected OBD II Ford trucks have a top speed governor. Normally they're set at around 94-96 mph. I've hit the governor in my E-150 but haven't been able to find it in my E-350 V-10 because once I get to 100-ish mph my sanity takes over and I back it off. But the sensation you describe sounds exactly like the governor. But it shouldn't hit at 75, unless you're bumping up against the rev limiter, which is different than the speed limiter. What year, what engine, tranny, rear end gears, etc ?
Old Apr 23, 2004 | 03:28 PM
350wagon's Avatar
350wagon
My van is a 93 e350 club wagon with 3:56 rear end automatic overdrive trans. and a 351 windsor, thanks for the reply's ,I believe you are right about the governor because the van run excellant all the time!
Old Apr 26, 2004 | 06:46 AM
Big Blue E350's Avatar
Big Blue E350
I drive a white '01 E150 for work, and our gov hits at 85mph. How can that be changed?
Old Apr 26, 2004 | 08:53 AM
Slade901's Avatar
Slade901
By using a custom chip for your computer.
Old Apr 26, 2004 | 08:59 AM
pfogle's Avatar
pfogle
DEpending on the year ('01) you should be able to use a "tuner" to remove that pesky governer.. MY 92 E150 w/351 will run well over 120mph so unless yours is an ex-fleet truck then I'd be worried.
Old Apr 27, 2004 | 12:34 AM
Big Blue E350
Current fleet truck, they are an embarressment to the name. Unfortunately, the only van that we have had that was fast was a dodge. Somebody pulled the govner er sumthin I spose,... but anyway that thing would get up and skit. I wish the fords(that we have) did that. lol
Old Apr 27, 2004 | 09:19 PM
350wagon's Avatar
350wagon
Can anyone recomend the best chip or tuner?
