headers
Old Apr 18, 2004 | 06:05 PM
Hausladen's Avatar
Hausladen
headers
decided to put headers on my truck, i was looking at the bbk chrome headers, and just wanted some opinions on them.
Old Apr 19, 2004 | 02:45 AM
TNTsF-250's Avatar
TNTsF-250
What you should also look at is , the weld around each port, should stick up 1.16" or more , so when you put your gasket in place it well seat tight, i have headers on my F-250 (390) 75 truck and every time i do a starter i have to pull the header off , a slight pain ! ! yours may be different?
Old Apr 19, 2004 | 12:40 PM
dk5122's Avatar
dk5122
What year truck? Which engine?
Old Apr 19, 2004 | 05:46 PM
Hausladen's Avatar
Hausladen
it is a 98 with the 4.6, after doing some reading i went ahead and ordered the gibson stainless steel headers.
Old Apr 19, 2004 | 06:29 PM
dk5122's Avatar
dk5122
I've heard good things about Gibson headers.. Smart move with the stainless. Let us know how everything works out after the installation.. Dan
Old Apr 19, 2004 | 08:23 PM
Hausladen's Avatar
Hausladen
will do, it will probably be a couple of weeks, by the time they come and i get them installed, still deciding if i should do it myslef, or take it in, it looks fairly simple, i just hate to break of a bolt or something.
Old Apr 19, 2004 | 11:27 PM
Rambo's Avatar
Rambo
I just put the Gibson stainless-steel headers on my truck two weekends ago. It wasn't as big of a process as I thought it might be, it took about 4.5 hours to do both sides.
I noticed a difference in power and a little sound difference as well, not to mention I'm getting about another mile per gallon on my 5.4L engine now.
Just an FYI, I got the headers which came with all the bolts needed supposedly, but one of the bolts they provided was too long to fit into the spot. So I had to go to the local hardware store and get a 2 1/4 inch long half inch bolt... I'm not sure why they didn't send a bolt that would actually fit, but they did. I thought I made the mistake at first and was using the wrong bolts, but they are the only ones that even come close to fitting. Anyway, thats just a heads up for you
Hope you like the headers.
Old Apr 21, 2004 | 11:37 PM
Cliffdogg's Avatar
Cliffdogg
headers for 5.0 mountaineer
anyone know where I can get a hold of some headers for a 5.0 mercury mountaineer?
Old Apr 29, 2004 | 08:02 AM
Hausladen's Avatar
Hausladen
well, i got the headers put on, all i have left now it to wait till my dipstick tube comes in that i managed to break well trying to get it out. Intall was not to bad, passenger side was simple, well drivers was a bit more complex, well removing the drivers side manifold i broke one of the studs off, leaving only about a inch exposed, i tried welding a nut on the end of it, but it was seized so bad in the head, that the weld on the nut broke from wrenching on it so hard, so i ended up leaving that stud in, i was able in get a nut started on it, so i think it will be ok, i am going to just tack weld the nut on there so it won't back off, i hate to but i see no other way at this point, another thing was getting the 4 bolts out of front driveshaft, finally after two days of soaking them with wd40, i was able to free them, with a wrench and a piece of pipe, and lots of force. I recommend if one wants headers, don't wait till truck has 150,000 miles on it, things are really rusted in them by than. Egr was also fun, took a few times with torch to get that out. But all in all it went well, just not as good as i was hoping. now i just wait for the dipstick tube to come in so i can fire it up.
Old May 4, 2004 | 08:03 PM
Hausladen's Avatar
Hausladen
well still waiting for my dipstick tube to come in so i can drive it, but i just couldn't wait any longer to hear it so i fired it up, and i can definelty notice a differnce in sound, but i got another problem, header is leaking in same spot as manifold was.
mooray
Exhaust Systems
Aug 29, 2010 02:04 PM
Jan 15, 2003 10:53 PM
gtex
Dec 26, 2002 12:20 AM
weldman
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 1, 2002 10:32 AM
Nathan
Exhaust Systems
May 19, 2000 09:03 PM
