Paint 4 interior plastic?
Old Apr 17, 2004 | 11:11 PM
Rascallyone's Avatar
Rascallyone
Just ordered a 3 gauge A pillar pod but it comes in black plastic and my interior is gray. Any suggestions for the best match of 1998 Ford OEM Gray that will adhere to plastic?
Old Apr 17, 2004 | 11:29 PM
Hi Ho's Avatar
Hi Ho
I used Krylon Fusion paint to paint the door panels along with some other plastic panels in my 77. It is holding up very well.
Old Apr 18, 2004 | 02:04 PM
Aekisu's Avatar
Aekisu
<cr>
SEM makes a rattle can primer called Flexible Primer Surfacer (product 39133) that is designed for plastics. After using it, you could apply any color you wanted.
Old Apr 24, 2004 | 06:46 PM
77300i6's Avatar
77300i6
As with any paint application make sure your surface is preped according to the dtrections on paint your using. The more time you spend in the beginning the happier you'll be longer.:cool
