75 psi on gauge testing AC
Old Apr 17, 2004 | 11:32 AM
scraprat's Avatar
scraprat
Top Answer: 5
Question 75 psi on gauge testing AC
I have a 99 250SD w/5.4, turned on ac but didn't feel cold air coming out, thought maybe needed refrigerant got 2 cans and bought the service kit from NAPA. After putting the guage on to see how much pressure was in the system it read 75psi(danger over charged), the compressure clutch was not engaging at all (watched 5min.).Anyone might have any insight on this problem?
Old Apr 17, 2004 | 05:35 PM
TNTsF-250's Avatar
TNTsF-250
What i'd try next is to lowcate your low side pressure switch , with the engine at idle ture on your a/c unplug the low side switch using a wire jump it over , this is to check if it well turn on your clutch at the compresser , if it turns on try a new low switch.
Old Apr 18, 2004 | 05:52 PM
scraprat's Avatar
scraprat
Top Answer: 5
Thanks TNT for the reply, ok where is it and what might it look like?
Old Apr 19, 2004 | 01:56 AM
TNTsF-250's Avatar
TNTsF-250
It should be on your a/c line, low side , if you have a manual it well show you,its about 2" long and 1" around, one plug with two wires in it.
Old Apr 24, 2004 | 05:59 AM
scraprat's Avatar
scraprat
Top Answer: 5
thanks Tnt, bought one I'll mess with this weekend.
Old Apr 24, 2004 | 04:26 PM
TNTsF-250's Avatar
TNTsF-250
You are welcome scraprat, i hope what helped.
