Throttle body swap
Old Apr 16, 2004 | 07:26 PM
93superflare's Avatar
93superflare
Question Throttle body swap
Anybody know if it's possible to swap the throttle body from my 93 5.0L to a bigger stock throttle body from a different engine? I know my chip will have to be reburned and I plan to swap out to 24# injectors when I make my other major engine mods (cam, heads, stroked crank, oversize pistons, etc), I just don't want to have to spend all that money for a High perf part if I can get the same reults from a cannibalization. Anyone?
Old Apr 17, 2004 | 01:39 PM
94F150-408's Avatar
94F150-408
You might want to check out one off of a 460, it's the same set-up. You'll have to check to see how much larger the bore size is, but it will bolt on.
