Sponsored by: Auxito
Brake Question
Old Apr 16, 2004 | 06:52 PM
onedangerouswookie's Avatar
onedangerouswookie
Unhappy Brake Question
I got a question that any help would be gladly appreciated. I changed my brake pads today. After I was finished I got in and my pedal was easily pushed all the way to the floor. I pumped the pedal several times trying to build pressure but no luck. I tried bleeding the brakes and I still have the same problem. They were working fine before I put new pads on it, just the pads were wore. Please Help!!!!!!!! Thanks!!!!!!!!!
Old Apr 17, 2004 | 12:18 AM
LxMan1's Avatar
LxMan1
It is normal to do that for the first couple of pumps after the caliper pistons are pushed back in, but it should have pumped back up. Did you have a helper pump the brakes while you bled them? Did the fluid have any pressure when you opened the bleeders?
Old Apr 17, 2004 | 11:10 AM
onedangerouswookie
Yes I did and I did have pressure. I called a brake guy and he said sometimes you had to bleed the brakes a couple of times to make sure you get all the air out of the lines??? Im going to try again today. Wish me luck!
Old Apr 17, 2004 | 02:10 PM
PaulC's Avatar
PaulC
I Suggest pressure bleeding next time. That ABS plumbing is a pain to purge air out of.
Old Apr 17, 2004 | 02:19 PM
onedangerouswookie
Talking
Thanks everybody for your help. I had to end up taking it to a garage to get the air out and a new bleeder valve that was stripped. All in all it was the best 34 dollars I ever spent! Thanks again!
