Need help
Old Apr 16, 2004 | 04:10 PM
Joey2004's Avatar
Joey2004
Need help
I have a 1948 F-3 Ford that I am completely restoring.It was bought in a junkyard and their was no title.To register for a title I need the VIN number.I have searched all over for the VIN and can't find it.Am I looking in the wrong place?Can you help?It would be very much appreciated,thank you.
Old Apr 16, 2004 | 05:56 PM
tlb's Avatar
tlb
I have a 48 F1. The vin # is located on the inside of glove box door. I think the engine # is same as vin#
Old Apr 17, 2004 | 07:08 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Joey,
I also have a 48 F-3. Someone replaced the glove box door on mine with one from a 49 F-4, so I have no idea what the correct VIN is on mine is either. There's supposed to be a number on the frame somewhere but I haven't found one yet. Good luck on the restoration...glad to see another old truck brought back to life.
Vern
Old Apr 17, 2004 | 07:22 AM
1952FORD's Avatar
1952FORD
1952 F1 have a number on top of the right frame rail above the front axle you might look there clean it with a steel wool pad
Old Apr 17, 2004 | 09:28 AM
mtflat's Avatar
mtflat
Hi Joey, welcome to FTE. Any chance you could apply for lost title with your bill of sale? All states are different.
I wouldn't have found my serial number on the frame if I hadn't had all the sheetmetal pulled off. It is a faint stamping (mine is near the passenger side motor mount, others have found theirs on the driver's side) and mine contains only the serial number. After using steel wool and solvent, shine a light at an oblique angle to see the stamping. The rest of the vin was given by the model of the truck and engine.
A '48 F3 would be: * 88RY 123456 * for an 8 cylinder and * 87HY 123456 * for a 6 cylinder. First character is year, second and third characters are engine, fourth is model (F3)
Terry, the vin up thru '47 is actually found on the transmission flange, not the engine. '48 - '53 they stopped doing that and went by chassis vin, located on the data plate/firewall, rating plate/glovebox door, and frame rail. And as always, there are exceptions.
