Trouble Code Help
Old Apr 16, 2004 | 01:29 PM
mikeh98's Avatar
mikeh98
Question Trouble Code Help
I have the following trouble codes in memory (check engine light cleared after 2-3 engine cold warm cycles) and know what they are called but don't know what they mean. Can anyone help?
They are in order P1151, P0171, P0174.
Lack of upstream HO2S sensor and bank one and bank two lean. Just what caused these?
Thanks,
Mike
1998 Ranger XLT Supercab w/ 4.0L V6 and Automatic transmission.
Old Apr 16, 2004 | 04:33 PM
stupid red ranger's Avatar
stupid red ranger
Both banks running lean. Perhaps something wrong with fuel delivery system?
Old Apr 16, 2004 | 10:23 PM
Rockledge's Avatar
Rockledge
Could be, maybe a clogged fuel filter or something like that.
Could also be a dirty MAF sensor, as discussed in this TSB. Probably worth cleaning it, in any case, since it's cheap and easy: Cleaning the MAF Sensor
My hunch is that its related to an air/vacuum leak somewhere. Check all vacuum hoses and connections, look over the EGR assembly, make sure the PCV valve and grommet are seated properly, any possible place where unmetered air can be drawn in.
Also, the 4.0L is somewhat prone to developing intake gasket leaks which can cause lean conditions.
Old Apr 17, 2004 | 02:18 PM
lbokc's Avatar
lbokc
Mine was fixed when I just tightened the bolts on the intake. Code never came back.
lbokc
'02 Ranger XLT 4.0
msradio
Jan 22, 2013 08:16 AM
TexasGuy001
Feb 22, 2010 06:31 AM
MrBookworm
Jan 28, 2006 09:47 PM
m68162
Nov 6, 2003 11:47 PM
theleetbeagle
May 26, 2001 08:02 PM
